Solving Inclined Plane Problems
In summary, the problem involves finding the frictional force and horizontal force acting on a 100kg block being pulled with a force P down a ramp at a 20 degree angle with a coefficient of friction of 0.7. Using Newton's second law, the net forces on the block can be set equal to 0, resulting in two equations with two unknowns (P and F(f)). Solving these equations results in P = 267.80N and F(f) = 848.10N. However, there is an error in the substitution of equation 2 into equation 1, resulting in incorrect values for P and F(f). Further work is needed to correctly solve for these values.
zesi
A block with a mass of 100kg is being pulled with a force P in and effort to move it down the ramp. The ramp makes a 20 degree with the horizontal ground. The coefficient of the friction between the ramp and the block is 0.7.
Find the frictional force and the horizontal force.
Assume g=10m/s^2
Inclined plane equations
Let
F(y) = vertical force due to gravity.
F(py) = vertical force due to applied force.
F(x) = horizontal force due to gravity
F(px) = horizontal force due to applied force P.
F(yNet)
= Total vertical net force
= F(y) - F(py)
= mg(cos(theta)) - P(sin(theta))
= 1000cos20 - Psin20
F(xNet)
= Total horizontal net force
= F(x) + F(py)
= mg(sin(theta)) - P(cos(theta))
= 1000sin20 - Pcos20
Am I doing it right above?
Let
F(N) be the normal force.
My rationale is that since the horizontal force P lifts the mass upwards, it's force acting downwards will be reduced.
Am I right to say that,
F(N) = F(yNet)
Normal force = The net force acting vertically downware to the ramp.
Am I getting the concept right or wrong?
I am now stuck at this part because I have so many unknown. I still can't find P. Can someone correct my understanding? Thank you all.
What happened to the friction?
Sorry let me re edit again for F(xNet)
Let F(f) = Frictional Force
F(xNet)
= F(x) + F(px) - F(f)
= mg(sin(theta)) + P(cos(theta)) - F(f)
= 1000sin20 + Pcos20 - F(f)
I still can't figure how to find the frictional force.
I know
F(f)
= F(N) * mu
= F(yNet) * 0.7
= 700cos 20 - 0.7Psin20
Did I make anymore mistakes? How do I move on from here?
I haven't gone through all your work. Your use of the word "net" is what is confusing me.
Assume for this problem that the force P is just large enough to get the block moving, but no more than that. If you prefer, you may think of the block sitting at rest on the ramp, but just almost enough to start moving. Or alternately, if it is moving, it is moving down the ramp at a constant velocity. My point is that it is not accelerating.
Given the lack of acceleration, what does Newton's second law of motion tell you about the net force on the block?
The next step is to break of the force equations into their x- and y- components. That will give you two simultaneous equations (one for the horizontal and another for the vertical). Two equations, two unknowns. :wink:
I have broken down the forces and I am not sure if I am right. I will re-edit my working again.
(Note: Force P is parallel to the horizontal ground.)
F(gx) = Force parallel to the inclined due to gravity.
F(gy) = Force perpedicular to the inclined due to gravity.
F(px) = Force parallel to the inclined due to Force P.
F(py) = Force perpedicular to the inclined due to Force P.
Using Newton's second law, I will attempt to find the value P that allows it to move from rest. Net force = 0N
F(N) = The normal force perpendicular to the inclined.
For net force parallel to the ramp = 0N,
F(f) = F(gx) + F(px)
F(N)*mu = 1000sin20 + Pcos20
0.7(F(N)) = 1000sin20 + Pcos20
[Equation 1]
For net force perpendicular to the ramp = 0N,
F(N) = F(gy) - F(py)
F(N) = 1000cos20 - Psin20
[Equation 2]
Substitute equation 2 into equation 1.
0.7(1000cos20-Psin20) = 1000sin20+Pcos20
Eventually I get
P=267.80N approximately.
F(f)= F(N) * mu
F(f)
= 1000cos20-267.80sin20
= 848.10N
I get Force P=267.80N
Frictional Force = 848.10N
Both answers are still wrong. What am I doing wrongly?
Something goes wrong during your 'Eventually'. Please post the detailed working.
What is an inclined plane?
An inclined plane is a simple machine that consists of a flat surface that is at an angle to the ground. It is commonly used to reduce the effort needed to move an object from a lower to a higher position.
What is the formula for calculating the mechanical advantage of an inclined plane?
The formula for calculating the mechanical advantage of an inclined plane is MA = L/H, where L is the length of the inclined plane and H is the height of the inclined plane.
How does the angle of the inclined plane affect its mechanical advantage?
The steeper the angle of the inclined plane, the greater its mechanical advantage. This is because a steeper angle requires less force to move an object up the plane, making the task easier.
What are some real-life examples of inclined planes?
Inclined planes can be found in many everyday objects, such as ramps, stairs, and wheelchair access ramps. They are also used in construction, such as building ramps for vehicles to drive up and down, as well as in transportation, such as roller coasters and ski slopes.
How do inclined planes make work easier?
Inclined planes make work easier by reducing the amount of force needed to move an object. Instead of lifting an object straight up, which requires more force, the object can be moved up the inclined plane with a smaller force over a longer distance.
