Inclined Plane
  1. Dec 23, 2008 #1
    An inclined plane is 30 degrees above the horizontal with a 2 kg ball at the top. Assume no friction or air resistance, and assume acceleration due to gravity is 10 [m/s^2]. Find the acceleration of the ball in the vertical and horizontal.
    2. Relevant equations
    F = ma
    3. The attempt at a solution
    So my attempt at the problem is to draw a force diagram of the situation, and then rotate my axis so that the normal force points up, and the gravitational field force points 30 degrees left, like this: http://img49.imageshack.us/my.php?image=yghrtqi6.jpg
    So after that it's pretty easy to find the x and y components of Fg (since I know the hypotenuse is 20 N), but how do I find Fn?
  3. Dec 23, 2008 #2
    jgens
    Under your new coordinate system does the ball have any acceleration in the y component? What does that answer suggest about the forces in the y direction?
  4. Dec 23, 2008 #3
    Oh, I see! Since the coordinate system has been shifted 30 degrees the acceleration now points exactly in the x direction; this means the acceleration in the y-direction is 0. The y forces must balance (Fgy = -Fn), so the acceleration is just Fgx. Thanks!
  5. Dec 23, 2008 #4
    Theres a problem, i suggest. We are considering a ball not a block and hence we must consider pure rolling.But there is no radius given. So may be there is a problem with the question
  6. Dec 24, 2008 #5
    Doc Al
    Staff: Mentor
    Yes, a bit strange that they used a ball instead of block, but no matter. Since there's no friction, the ball will slide not roll. (Probably just an oversight.)
    If the ball did roll, then the acceleration would be different. But it would not depend on the radius.
  7. Dec 24, 2008 #6
    Oops. It would depend on radius of gyration but not radius.
  8. Dec 24, 2008 #7
    jgens
    Since there's no friction the ball will slide, not roll.
  9. Dec 24, 2008 #8
    Guys, there is a serious lapse in my concentration. First i write radius instead of radius of gyration and second i dont even read the question properly which says " no friction"
  10. Dec 24, 2008 #9
    Hi Pupil, I hope you got your questions answered. If you aren't studying rotational stuff right now, I would just model the ball as a point mass for this problem. Also, don't forget that Fgx is a force, not an acceleration. You must divide out the mass to get the acceleration..... Let us know if you've got it ok!
  11. Jan 1, 2009 #10
    Whoops! Yeah, I meant Fgx is a force (I occasionally mix my lingo when thinking about too many things at once). I think my teacher meant the ball as just some object sliding down a ramp. Thanks for the help guys!
Similar Discussions: Inclined Plane
  1. Inclined planes (Replies: 5)
  2. Incline Plane (Replies: 1)
  3. Inclined planes (Replies: 11)
Loading...
