Figuring Out Increase in Angle of Inclination
In summary, the conversation discusses the relationship between the angle of inclination and the acceleration of an object sliding down an inclined plane. It is mentioned that the acceleration can be calculated using the formula a=gsinθ, where g is the gravitational acceleration and θ is the angle of inclination. The group also discusses how the angle of inclination affects the acceleration and provides examples using the unit circle. Overall, the conversation focuses on understanding the concept of angle of inclination and its relationship to acceleration.
Temper888
Hey Guys,
I was doing physics questions. It was written that in the absence of friction, the acceleration of any object sliding down an inclined plane is given by:a=gsinθ. As the skier skis down the curved hill, the angle of inclination is increasing, so the acceleration of the skier is increasing. What I cannot figure out is how to know when the angle of inclination is increasing. For instance, I thought angle of inclination should increase while going up an incline. Could you please say me if there is a method of figuring out how a certain way(up or down) the incline leads to an increase or decrease in angle of inclination?
Thanks
The angle of inclination means the 'steepness' of the slope and is usually measured from the horizontal.
So a slope that is not very steep may be 10degrees and a steep slope may be 60 degrees.
Flat (no slope) is 0 degrees, vertical is 90 degrees
If the skier is coming down the hill at a 10° angle he would be going slower than if he were to be going down at a 60° angle due to the work of his weight.
In other words you said that a=gsinθ. Try to think of the unit circle; the bigger the angle, the closer the sinus gets close to 1 but only between pi and pi/2.
If the angle of the slope is 0 degrees he will not be accelerating due to his weight (Sine0 =0)
If the angle of the slope is 90 degrees (vertical) he will be falling freely under gravity and his acceleration will be = g (Sine90 =1)
If the slope is 30 degrees his acceleration will be g/2 (Sine30 = 0.5)
And so on...
And so on...
Yea kind of what I was trying to tell him but you explained it better.
1. What is the angle of inclination?
The angle of inclination is the angle between a reference plane and a line or plane that is tilted or inclined from the reference plane.
2. How is the increase in angle of inclination calculated?
The increase in angle of inclination can be calculated using the formula: increase in angle of inclination = final angle of inclination - initial angle of inclination.
3. What factors can affect the increase in angle of inclination?
The increase in angle of inclination can be affected by factors such as the force applied, the distance from the pivot point, and the mass of the object.
4. Why is it important to figure out the increase in angle of inclination?
Figuring out the increase in angle of inclination allows us to understand the motion and stability of objects that are tilted or inclined. It can also help in predicting the behavior of objects in different situations.
5. What are some real-life applications of figuring out the increase in angle of inclination?
Figuring out the increase in angle of inclination has many practical applications, such as understanding the stability of structures like buildings and bridges, analyzing the motion of objects on inclined surfaces, and calculating the force required to move objects up or down an incline.
