Homework Help: Include source code in latex
  1. Jan 12, 2013 #1
    I need some kind of environment in Latex where you can write whatever you want without it interpreting it. The reason is I need to include a matlab code. Most places I go says I have to use the lstlisting environment, but that doesnt work. Or at least I get this error:
    ! Package inputenc Error: Unicode char \u8:�\expandafter not set up for use wit
    h LaTeX.
    See the inputenc package documentation for explanation.
    Type H <return> for immediate help.
  3. Jan 12, 2013 #2
    gneill
    Staff: Mentor
    Code (Text):
    Can't you put
          your source code
          inside code
    tags?
  4. Jan 12, 2013 #3
    maybe. How do you make code tags?
  5. Jan 12, 2013 #4
    gneill
    Staff: Mentor
    Go back to my post and hit the "quote" button :smile:
    There's a button on the edit panel header, too; select the text to be wrapped in code tags and hit the icon.
    It's probably just as easy to type in the tags by hand.
  6. Jan 12, 2013 #5
    okay but this is for the messages on this site. Does it work in a latex document too? edit: ill just try ofc
  7. Jan 12, 2013 #6
    gneill
    Staff: Mentor
    No, it's for posts on this site. It wasn't clear to me that you wanted to create "free-form" text in a general LaTex environment. Sorry about that.
    A quick google turned up the listings package which might be of interest.
  8. Jan 12, 2013 #7
    D H
    Staff Emeritus
    It was pretty clear to me!
    aaaa202, the problem is that lstlistings only supports ASCII. Your code apparently contains non-ASCII characters. You need to use either the package listingsutf8 or listings and specify the encoding via \lstset.
  9. Jan 12, 2013 #8
    hmm yeh but as said I tried that one and I get the weird error:
    h LaTeX.
  10. Jan 12, 2013 #9
    okay I tried lstlset. Now I get error: "Package keyval error"
    edit: I am now using listingsutf8 with \lstset
  11. Jan 12, 2013 #10
    D H
    Staff Emeritus
    In the opening post you said you tried lstlistings. That package does not work with non-ASCII characters. That's what that cryptic message "Unicode char \u8:�" is about.
  12. Jan 12, 2013 #11
    sorry that comment was written before I tried your solution. Look my previous comment :)
  13. Jan 12, 2013 #12
    D H
    Staff Emeritus
    My mind reading skills aren't up to snuff today. How did you use \lstset? Did you read the documentation on it?
  14. Jan 12, 2013 #13
    well i just used listingsutf 8 and made a \lstset environment. Thought that did the trick, ill read the documentation. Just thought u might recognize the error.
  15. Jan 12, 2013 #14
    reading on the documentation didnt really help. I attached my error if you wonna try help me further :)
    [7 <./E1E0vsV0.png (PNG copy)> <./nbundnevsV0.png (PNG copy)>]
    <egentilstandedobbelt.png, id=46, 422.32782pt x 316.18124pt>
    <use egentilstandedobbelt.png> [8]
    <energiegen.png, id=52, 422.32782pt x 316.18124pt> <use energiegen.png>
    [9 <./egentilstandedobbelt.png (PNG copy)>]
    <hist.png, id=56, 422.32782pt x 316.18124pt> <use hist.png> [10 <./energiegen.p
    ng (PNG copy)>] <egentilstandeperiodisk.png, id=60, 422.32782pt x 316.18124pt>
    <use egentilstandeperiodisk.png>
    ! Package keyval Error: c undefined.
    See the keyval package documentation for explanation.
  16. Jan 12, 2013 #15
    D H
    Staff Emeritus
    You aren't showing the code. How did you use \lstset?
  17. Jan 12, 2013 #16
    The cheap way to do it, is the verbatim environment, but it will not have line numbers or syntax highlighting etc.
    Code (Text):
    \begin{verbatim}
    #include <iostream>
    using namespace std;
    int main(void)
        cout << "hello world\n";
        cin.get();
        return 0;
    \end{verbatim}
  18. Jan 12, 2013 #17
    D H
    Staff Emeritus
    I don't think verbatim can handle non-ASCII characters, either.
