Max Angle for Increasing Distance Projectile
  • Thread starter ExtravagantDreams
  • Tags
    Increasing
In summary: I would have thought the distance traveled would be proportional to the cosine of the angle. But it looks like that's not the case.In summary, the projectile can be shot so that its distance from the origin is always increasing if air resistance is neglected. The maximum angle is found to be approximately 70.356 degrees.
ExtravagantDreams
82
I'm having trouble getting the answer without doing a guess and check.
Q: Find the maximum angle a projectile can be shot so that it's distance from the origin is always increasing. Air resistance negleced.
So there is the x and y position based on initial velocity, angle, and time, but I made initial velocity equal 1 for simplicity. Next, make a vector out of this and find the distance of the vector at varying angle and time.
Take the time derivative and make sure it is never negative. Unfortunately, there is no angle where change in the projectile's distance is zero at the point where it lands, so I can not make the whole equation all in terms of the angle.
So what can I do?
I'm pretty damn sure the answer is ~70.356 deg.
I think you'll find that the distance the projectile travels is proportional to [tex]sin\theta \times cos\theta[/tex]. For what angle is that a maximum?
Please show the calculations that made you so damn sure!
well, I just graphed it over and over using a calculator changing the angle until I got really really close to a non posative slope.
has a maximum at 45 deg.
Position:
[tex]
x = v_{0x}t = v cos(\theta)t
[/tex]
[tex]
y = v_{0y}t -.5gt^2 = v sin(\theta)t - .5gt^2
[/tex]
Let [itex] \vec {C} [/itex] be the vector from the origin to the position of projectile
[tex]
\vec {C} = [x,y] = [v cos(\theta)t,v sin(\theta)t - .5gt^2]
[/tex]
[tex]
||\vec {C}|| = \sqrt{x^2 + y^2} = \sqrt{(v cos(\theta)t)^2+(v sin(\theta)t - .5gt^2)^2}
[/tex]
Take the time derivative and find where it equals zero. (let v=1 for simplicity)
[tex]
\frac {d||\vec {C}||} {dt} =\frac {2t + 4(4.9)^2t^3 - 3(9.8)sin(\theta)t^2} {\sqrt{( cos(\theta)t)^2 + (sin(\theta)t - .5gt^2)^2}}
[/tex]
But I can't do that without guessing and checking. I hoped to find the derivative of C to be zero at the landing point, so that I could sub all the t's for
[tex]
\frac {sin(\theta)} {4.9}
[/tex]
but no luck with that one.
If the projectile is launched from the origin (0, 0) then with x -> horizontal and y -> vertical we have [tex]x = v_{x0} t[/tex] and [tex]y = v_{y0} t - \frac{1}{2} g t^2[/tex]. Here [tex]v_{x0} = v_0 cos \theta[/tex] and [tex]v_{y0} = v_0 sin \theta[/tex].
The projectile will return to the ground at time [tex]t = T = \frac{2v_{y0}}{g}[/tex] at which time its horizontal displacement (range) will be [tex]x(T) = 2* sin\theta cos\theta v_0^2 / g[/tex].
By the way, "damn" is a verb - I am sure you meant to use the adjective or adverb form "damned!" :wink:
Well, you got a function of theta only, but I'm not so sure this helps me. I am not trying to find an angle that will give me maximum range, but a maximum angle that will yield increasing distance from the origin.
Make a graph of [tex]\sin \theta \times \cos \theta[/tex] and tell me what you see! :-)
How do I do a cross product of two scalars? I'm sure that's not what you ment. So, how does this help me?
It's not a cross product - it's scalar multiplication. That's a regular multiplication symbol! I'm not fully accustomed to this LaTeX system yet!
Ok, so how does that help?
[tex]\sin \theta \cos \theta[/tex]
is a function of maximum x-displacement.
The attached image shows the vector C that must never decrease in magnatude as the projectile moves along the arc.
hmm perhaps something to do with the tangent must not be perpendicular or turned to the right of C at time t
Thanks for the picture. It made me realize I was locked onto the wrong problem - i.e. it has nothing to do with range!
Here's what I tried - in outline form since the algebra gets to be a bit heavy: You can explicitly write the time dependent displacement (x, y) and velocity as vectors. Now form the scalar product of those two quantities. The result is proportional to the cosine of the angle that the position vector makes with the velocity vector.
As long as it is positive, the projectile is moving away from the origin. It's a complicated function of time but your objective is simply to determine when it is positive. Factor out from it everything that you can and recognize that time (t) is always nonnegative. You will end up with a quadratic function of time It is helpful to complete the square and, recognizing that the graph of the function is a parabola, you can determine the axis of the parabola. Basically you want a parabola that has a minimum at its vertex and the vertex must lie above the t axis. This places a constraint on [tex]\theta[/tex] and I finally arrived at the expression [tex]\sin \theta < \sqrt{\frac{8}{9}}[/tex] so the critical angle is [tex]\arcsin {\sqrt \frac{8}{9}}[/tex] which is pretty close to what you estimated in your original post.
I admit I was a little surprised the intial speed and acceleration cancel out. I want to think some more about this!
thanks for the help, I will have to try that out tomorrow
I am still not understanding. I completed the squares on [itex] \vec {C} \dotprod {\frac {d \vec {C}} {dt}} = 0[/itex] and get this really complex function that tells me nothing.
[tex]
.5g^2[(t - \frac {3 V_0 sin \theta} {2g})^2 + (2 - \frac {9} {4} sin^2 \theta) \frac {V^2_0} {g^2}] = 0
[/tex]
The scalar product of the Position vector and velocity vector give something with only one sine in it so I should be able to solve for theta but for some reason I get undefined. My algebra is probably just messed up. But thinking about doing it that way, I wouldn't know what I am looking for.
What is the "Max Angle for Increasing Distance Projectile"?
The "Max Angle for Increasing Distance Projectile" refers to the optimal angle at which a projectile should be launched in order to achieve the maximum distance traveled.
How is the "Max Angle for Increasing Distance Projectile" calculated?
The "Max Angle for Increasing Distance Projectile" is calculated using the equation: θ = arctan (v02/gR), where θ is the angle of launch, v0 is the initial velocity, g is the acceleration due to gravity, and R is the range of the projectile.
What is the ideal value for the "Max Angle for Increasing Distance Projectile"?
The ideal value for the "Max Angle for Increasing Distance Projectile" depends on the initial velocity and range of the projectile. However, in most cases, it is found to be around 45 degrees.
How does air resistance affect the "Max Angle for Increasing Distance Projectile"?
Air resistance can decrease the "Max Angle for Increasing Distance Projectile" by reducing the velocity and increasing the time of flight of the projectile. This results in a shorter range and a smaller optimal angle for maximum distance.
Can the "Max Angle for Increasing Distance Projectile" be greater than 90 degrees?
No, the "Max Angle for Increasing Distance Projectile" cannot be greater than 90 degrees as this would result in the projectile being launched downwards instead of upwards.
