Indefinate integral
  1. Aug 17, 2011 #1
    find the integral from (2 to infinity) of 1/(1+e^x)
    2. Relevant equations
    3. The attempt at a solution
    lim(t-->infinity) integral from (2 to t) of 1/(1+e^x)
    1/1+e^x = (1+e^x-e^x)/(1+e^x)
    = 1-e^x(1+e6x)
    when you solve the integral:
    x-ln(1+e^x) between 2 and t
    t-ln(1+e^t)-(2-ln(1+e^2))
    here we're confused, because when you plug in t=infinity, you end up with a limit that doesn't exist... help?
  3. Aug 17, 2011 #2
    HallsofIvy
    Well, first, of course, you don't find a limit by "pluggin in t= infinity". This of the form "infinity- infinity" so you should be able to use L'Hopital's rule.
  4. Aug 17, 2011 #3
    then i should hve 1-(e^x)/(1+e^x)?
    and use l'hospital's rule again and have
    -(e^x)/(e^x)
    =-1?
  5. Aug 17, 2011 #4
    dynamicsolo
    You are confronted at this point with the limit
    [tex]\lim_{t \rightarrow \infty} t - \ln | 1 + e^{t} | - 2 + \ln | 1 + e^{2} | [/tex]
    Plainly, that t - 2 is going to be a problem (and pulling the logarithms into a single term isn't much better). Try writing the other two terms as logarithms, e.g. , [tex]t \rightarrow \ln(e^{t}) ,[/tex] and write the entire limit expression as a single logarithm. With a little manipulation of the ratio in the argument of the logarithm, you'll find you won't even need l'Hopital...
  6. Aug 17, 2011 #5
    Ray Vickson
    In order to get a finite result for int_{x=2..infinity} f(x) dx (f(x) > 0 for all x >= 2) we need f(x) to go to zero quickly enough as x --> infinity. Does this happen for your f(x)?
    RGV
  7. Aug 17, 2011 #6
    vela
    Staff Emeritus
    Education Advisor
    No. You need a quotient to apply the Hospital rule, so you'd need to rearrange your expression first.
    I think the most straightforward way to evaluate the limit is to use
    [tex]t-\log(1+e^t) = t-\log[e^t(1+e^{-t})][/tex]
    Use the properties of log to simplify your expression and then let t go to infinity.
