Independence of Path: Understanding Line Integrals in the xy-Plane
In summary: So, you are correct that you can use either theorem to show that this integral is independent of path. In summary, the given line integral is independent of path in the entire xy-plane because it is a total derivative, a contour integral of an analytic function, and satisfies the necessary conditions for a conservative field. Additionally, both Green's and Stoke's theorems can be used to prove this independence of path.
kasse
384
Why is the given line integral independent of path in the entire xy-plane?
Int((y2 + 2xy)dx + (x2 + 2xy)dy)[/i]
Because it's a total derivative?? Because regarded as a line integral of a vector field it's curl is zero?? Because it's the contour integral of an analytic function?? Take your pick, depending on the course you are in. They are all the same. Show one of them.
If you know Greens or Stokes theorem, you should check them out for this -- that is perhaps the quickest way to see the answer by just looking at the integral.
If not, then have you talked about conservative fields? You should check out what the necessary conditions are for a conservative field and apply it here.
Stoke's theorem clearly does not apply here. Green's theorem does but is far more general than needed here. As Dick said, your answer will depend upon the course, but the simplest thing to do is show that (y2 + 2xy)y= 2y+ 2x= (x2 + 2xy)x and so this is, as Dick said, a "total derivative" (I would say an "exact differential"): there exist a function F(x,y) having this as its differential. The integral along any curve is just the difference of F evaluated at the two endpoints.
Stokes would deffinitely work. You just set your vector field equal to F=<y^2 + 2xy, x2 + 2xy,0> and then he has the integral F.dr. You use stokes theorem and get the same answer as greens would give you. But maybe I am missing something because I've only recently started studying Stokes.
Stoke's theorem refers, in general, to an integration over a curved surface in R3. Green's theorem refers to an integeration over an area of R2. If you take your surface to be the xy-plane, then Stoke's theorem reduces to Green's theorem.
What is the concept of independence of path in line integrals?
Independence of path is a concept in line integrals that states that the value of the integral does not depend on the specific path taken to reach the endpoints. This means that the integral along any path between two points will yield the same result.
How is the concept of independence of path applied in the xy-plane?
In the xy-plane, the concept of independence of path is used to evaluate line integrals along curves or paths that lie in the xy-plane. The integral will have the same value regardless of the specific path chosen, as long as it starts and ends at the same points.
What is the significance of the xy-plane in understanding line integrals?
The xy-plane is important in understanding line integrals because it provides a two-dimensional coordinate system that allows for the evaluation of integrals along curves in the plane. This allows for the application of concepts such as independence of path and the use of parametric equations to describe curves.
How do you calculate line integrals in the xy-plane?
To calculate line integrals in the xy-plane, you can use the fundamental theorem of line integrals, which states that the integral of a function over a curve can be evaluated by finding the antiderivative of the function and evaluating it at the endpoints. Alternatively, you can use parametric equations to describe the curve and use the appropriate formula for line integrals.
What are some real-world applications of line integrals in the xy-plane?
Line integrals in the xy-plane have many real-world applications, such as in physics, where they are used to calculate work done by a force along a curved path. They are also used in engineering, such as in calculating the flow of fluids or electric currents along a curve. Additionally, they have applications in economics and other fields that involve the calculation of quantities along a given path.
