Indeterminate forms
  • Thread starter erisedk
What is the right hand and left hand limit of (sinx)^tanx?
I know this is an indeterminate form 0^0 but what are the RHL and LHL because though I intuitively know that 0^0 is indeterminate, I don't understand what the right hand and left hand limits are?
Answers and Replies
As I implement!!
$$\lim_{x\rightarrow 0}sinx^{tanx}$$
look at the graph of the function
http://www.wolframalpha.com/input/?i=sin x^{tan x}
And this is intuitively reasonable,
Let us assume a very small value approaching to zero for theta [in radians] , say 0.00000001, then the value will be very close to 1
This is the limit from the right .
And the limit from the lift doesn't exist since you x^x is not always valid for negative numbers..,
Hope that is right and what you are looking for ,,
HallsofIvy
41,847
969
It doesn't make sense to talk about "limits" at all without saying what x itself if going to. I presume here you mean "limit as x goes to 0". The "left hand limit" would be as x approaches 0 "from the left" on the number line- that is, x is always negative. The "right hand limit" would be as x approaches 0 "from the right on the number line- x is always positive.
You should be able to see from your graph that if x is approaching 0 "from the right" or "from above", then f(x) goes to 1 while it cannot approach 0 "from the left" or "from below" because, as Maged Saeed said, sin(x)tan(x) is not defined there.
Ok thanks :D
Related Threads on Indeterminate forms
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
