Index of Refraction
  • Thread starter matt72lsu
matt72lsu
94
While studying physics at the library late one night, you notice the image of the desk lamp reflected from the varnished tabletop. When you turn your Polaroid sunglasses sideways, the reflected image disappears.
If this occurs when the angle between the incident and reflected rays is 110 degrees, what is the index of refraction of the varnish?
tan theta = n2/n1
I used n2 = air (1) and solved for n1 but was incorrect. Where am I going wrong?
Answers and Replies
rock.freak667
6,223
31
Well because it is reflected, it sounds like you have a case of total internal reflection. You'll need to use sinC = 1/n.
AtticusFinch
129
tan theta = n2/n1
Ah so close. You are correct in using the Brewster's angle formula. However notice the trick in the problem. They tell you the angle between the rays NOT the angle the rays make with normal.
matt72lsu
94
so would i do 180-110 or something like that? the angle thing is messing me up
rl.bhat
4,433
No.
During reflection angle of incidence is equal to angle of reflection. In the problem, the sum of the angle of incidence and angle of reflection is given. from that find the angle of incidence which is the polarizing angle.
AtticusFinch
129
Yes what rl.bhat said is correct. If you are still having trouble thinking about it, try drawing a diagram and setting the reflected and incident angles to the normal equal. Also set the angle between the two rays equal to 110.
Suggested for: Index of Refraction
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
