Index two.
Main Question or Discussion Point
Is it true that if a finite group G contains a subgroup of index 2, then there is an element of G with order 2?
Answers and Replies
I'm thinking that if H is a subgroup of index 2, then H is normal in G. Then for all x in G, xH=Hx, so (xH)(Hx)=H and xHx=H. So x=x^-1 and x has order 2. Is this correct?
The statement is true. If G has finite order and a subgroup of index two, G must have even order by Lagrange's theorem. Then, you can easily prove there must exist an element which is its own inverse. In fact, this is a standard exercise in any text.
Regarding your proof: Is multiplication of a left coset by a right coset well defined? And why do you end up with H on the right side? Doing this assumes xx=e.
You're right.
But you have to have x^2 in H for all x not in H. (xH)(xH)=H because otherwise, it would be an identity: (xH)(xH)=(xH) and cancellation gives that x is in H.
I don't see any way to prove this.
Related Threads on Index two.
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
