How Does a Time-Varying Magnetic Field Induce Current in a Circuit?
In summary: I2 and I3. In summary, Jordan found that the current through the circuit will be three different currents, I1, I2, and I3, and that they will run in opposite directions. He also found that the resistance will be proportional to the length of wire in the circuit.
jordanl122
This one is really getting to me.
Find the current through section PQ (the middle column of the circuit) of length a, a =.65 m. The circuit is located in a magnetic field whose magnitude varies with time according to the expression B(t) = .001t. Assume the resistance per length of wire is .1 ohm/m.
Diagram:
key: I: piece of circuit
X: direction of B field
-----------P
IIIIIIIIIIIIIIIIIIIIIIIII
I X X X X I X X X I
I X X X X I X X X I a
I X X X X I X X X I
-----2a---Q----a---
I started by using Faraday's law of inductance,
Emf = -d Phi_m/dt
but I am not exactly sure how this will help me. I foresee a kirchhoff analysis, but I'll be damned if I can figure out how I arrive there
Jordan,
So using Faraday's law, what did you get for the emf around the left and right loops?
for the bigger section I got..
Emf = -2(a^2)dB/dt
= -2(a^2)*.001 d/dt (t)
= -.001*2*.65^2
= -8.45*10^-4 V
and smaller
Emf = 4.225*10^-4 V
jordan,
The Emf magnitudes look right. Did you mean to say one was positive and the other negative? What would that mean?
Now think about currents. How many different currents will there be in the circuit?
I'm thinking three, since it splits at some point. And I meant to make the second Emf negative as well. Now this definitely seems like a kirchhoff set up, except that I'm not exactly sure how to play the resistance.
Im thinking if we treat each section like loops, then the current is going to be counterclockwise through each section. Since the initial flux is going into the page. The B field generated in response to maintain constant flux over the system is going to be out of the plane of the page. And hopefully, I am applying the right hand rule correctly here.
To deal with the resistance, I am guessing I just find the total resistance in each segment of the wire, and treat it as if it were a regular resistor in the circuit. And along that same path of logic, I can treat the emf as a battery somewhere in each loop.
Feel free to continue steering me in the right direction if I'm heading way off course.
jordan,
Doin't worry, you're not far off course. But hold off on replacing the Emf with a battery. That only works if the current everywhere in the loop is the same. We're not going to be that lucky.
You said there are three different currents. That's right. Call them I1, I2 and I3. You need to decide how to define them. So, where is each one, and which direction is each one going in?
damn, I was almost positive it was going to be two batteries, one for each corresponding loop. As for the currents, would it be I1 traces out the bigger rectangle and splits off into I2 and I3. I2 running up the section we are looking for, and I3 running around the smaller rectangle
That will work fine for I1, I2 and I3. Now you need to find some (namely three) equations for them. Any ideas?
well I1 = I2 +I3 is in the bag. So I guess I'll follow each individual loop to generate the two other equations. And scuttling along with the resistance length and two battery idea, seeing as it will all come out in the kirchhoff loop rule wash anyway... I run into some trouble because I don't know what direction my batteries are, or should I just directly sub in my emfs and hope for the best. Anywho my second equation is:
(emf1 is the emf from the bigger section, and emf2 is the emf from the smaller one)
emf1 -.325I1 -.065I2 = 0
and my third:
emf2 + .065I2 - .195I3 = 0
to get those three resistor values I multiplied the length of wire by the resistance per unit length
so .1(5a) = .1(5*.65) = .325 ohms
and .1(a) = .065 ohms
and .1(3a) = .195 ohms
since those are the three lengths upon which the three currents run
jordan,
Lookin' good! You just go around the loop, and if you hit a current going the other way, you make the voltage contribution from that link negative.
So, since you know the emfs, you have 3 equations in 3 unknowns. I'd use the first one to eliminate I1 in the second, then solve the second and third for I2 and I3.
Go for it!
I thank you oodles friend.
-Jordan
jordan,
You're welcome, but you did most of it.
By the way, after looking at what you did, I retract what I said about not being able to treat the Emf as a battery in the loop. Your second and third equations said that the sum of the voltage drops around each loop had to be the same as the Emf, but that's the same as saying they have to be the same as the voltage across a battery. I don't know what I was thinking!
1. What is induced current in a circuit?
Induced current in a circuit refers to the production of an electric current in a conductor or circuit due to a changing magnetic field. This can occur through various means, such as electromagnetic induction or mutual induction.
2. How is induced current different from direct current?
Direct current (DC) is a type of electric current that flows in one direction, while induced current can change direction depending on the changing magnetic field. DC is generated by a constant voltage source, while induced current is generated by a changing magnetic field.
3. What factors affect the magnitude of induced current?
The magnitude of induced current is affected by the strength of the changing magnetic field, the speed at which the magnetic field changes, and the number of turns in the conducting loop or coil.
4. How is induced current used in everyday devices?
Induced current is used in a variety of everyday devices, such as generators, transformers, and electric motors. These devices use induced current to convert mechanical energy into electrical energy, or vice versa.
5. Can induced current be harmful?
Induced current can be harmful if it is of high magnitude and duration. This is why precautions are taken to minimize exposure to sources of induced current, such as power lines and electrical devices. However, induced current can also be used in medical devices, such as TENS machines, for therapeutic purposes.
