Induced Electric Fields in Changing Magnetic Fields: Equations and Applications
In summary: This propagation is very important and is precisely what is meant by electromagnetic radiation, and the speed of propagation is precisely c, the speed of light.In summary, the conversation discusses the effects of changing magnetic fields and how they propagate in space, as described by Faraday's law of induction and Maxwell's equations. The proof of a bicycle wheel's final angular speed after a magnetic field is switched off is also discussed, raising questions about the behavior of fields at points of discontinuity. However, it is established that the propagation of changes in fields is a fundamental aspect of electromagnetic radiation and is governed by the speed of light.
pardesi
339
suppose there is a region S through which the magnetic field changes with time then is the electric field induced there only or everywhere in space .
if everywhere what equations does it satisfy
Interesting question, the relevant equation is Faraday's law (of induction) and the effects propagate outward from the event at the speed of light, eventually (in classical theory) making a contribution to every point in space.
but going by what maxwell says
[tex] \nabla \cross E= -\frac{\delta B}{\delta t}[/tex]
if at a point B does not change then no curl of E hence most probably no E .
in fact if we have the surrounding region of E also curl 0 with the condition that
[tex]\nabla.E=0[/tex] and the boundary condition we have indeed [tex]E \equiv 0[/tex]
Sorry I am out of practice with TeX
E = -grad(V) + A'
where A is the vector potential and prime denotes derivative with time. Look for a discussion of retarded potentials to see how A propagates with time, but suffice to say it does, and whatever changes happen to A at a particular point d distance away from me will in principle be felt after a duration t = c/d, where c is the speed of light.
Edit: If B changes at a single point, then that change will eventually propagate away, but your argument assumes that B can change at one isolated point only, when this is impossible under the assumption of continuous fields i.e. the differential form of Maxwell would not apply at that point of discontinuity. Granted, discontinuities can occur in the theory of Maxwell's equations n matter, but I am not qualified to give an answer that takes matter into account.
so no matter where in space the magnetic field changes every point in space feels the change that is there exists a time t when it experiences the field
well the actual doubt arose from a very well known question having a strange field
the question
a bicycle wheel has linearcharge [tex]\lambda[/tex] glued to it in the rim which is very thin.Also the spokes ar non conducting.Radius of the wheel is [tex]b[/tex].A magnetic field [tex]\vec B_{0}[/tex] exists in the circular region around the centre of wheel within radius [tex]a <b[/tex] coming out of the plane of the wheel.The field is insytantaneously switched off find the final angular speed of the wheel.
Well the proof started by assuming the flux change across the rim obeys farady's law but doesn't that seem strange .Field actually changes at a point and effects are felt elsewhere
The magnetic field exist in the prescribed region, but it does not say that this is the only region where a non-zero magnetic field exist, and in particular the field could not be discontinuous so it must be non-zero around the fringes of the described region.
I am not totally satisfied with the answer I have given concerning discontinuities, but the one about propagation is more solid. If B changes at a point, this induces the curl of E at that point, but this non-zero E acts as a displacement current to produce a B in an (infinitesimal but slightly larger) Amperian loop, which is changing and so produces E in a slightly larger infinitesimal loop etc.
What is the equation for calculating the induced electric field in a changing magnetic field?
The equation for calculating the induced electric field in a changing magnetic field is given by Faraday's Law of Induction: E = -dΦ/dt, where E is the induced electric field, Φ is the magnetic flux, and t is time.
How do induced electric fields affect conductors?
Induced electric fields can cause currents to flow in conductors, resulting in the production of heat and potential damage to the conductor. This effect is known as eddy currents and is commonly seen in electrical transformers.
What is the difference between induced electric fields and static electric fields?
Induced electric fields are created by changing magnetic fields and are temporary, while static electric fields are created by stationary charges and are permanent. Induced electric fields can also be shielded by conductive materials, while static electric fields cannot.
What are some practical applications of induced electric fields?
Induced electric fields have various practical applications, including the generation of electricity in power plants, the operation of electric motors, and the functioning of magnetic resonance imaging (MRI) machines.
How can the strength of an induced electric field be increased?
The strength of an induced electric field can be increased by increasing the rate at which the magnetic field changes, increasing the number of turns in a coil of wire, or by using a stronger magnetic field. Additionally, using a ferromagnetic material can also increase the strength of the induced electric field.
  • Electromagnetism
  • Electromagnetism
