• Support PF! Buy your school textbooks, materials and every day products Here!
Induced tension magnetic field (B)
I have the strength of the magnetic field, B, the time, Delta t, a circle formed ring with the diameter, d. I should calculate the induced tension, when the surface is
(a) parallel to the B field
(b) 50 degrees on the B field
Need help to solve it (symbolic if possible).
I thought of something like:
[tex] $U_H = A_H \frac{I B}{d}$ [/tex],
but I don't have "I". And there are no angles there. Please tell me how to solve it symbolic.
Please look the (2).
Answers and Replies
BvU
2019 Award
13,367
3,169
Hello Basip, welcome (back) to PF :smile: !
Could you please re-read your posting and complete the problem statement ? Perhaps even add a little drawing ? It is now rather unclear what the exercise wants you to do. It's fine if you mention ##\Delta t##, but what it its role in this problem ?
Also all and any symbols you want to use in part 3 need clarification. ##U_H## is probably the induced emf ? and ##A_H## an area ? Don't let us guess unnecessarily !
And you can do displayed equations with $## ##$U_H = A_H \frac{I B}{d} $## ##$ to get $$ U_H = A_H \frac{I B}{d} $$ and in-line equations with ##\#\# ##U_H = A_H \frac{I B}{d}##\#\# ## to get things like ##U_H = A_H \frac{I B}{d} ##
However, your equation doesn't make much sense to me. You sure it fits in the problem context ? Could it be you need something else ?
Dear BvU!
Thank you for your help so far. I don't know how to edit my question, so I reply here.
Variables to play with
$$B=0.58T$$
$$ \Delta t=0.10s$$
$$d=0.105m$$
Question formulation
In a magnetic field, B, at the time, ## \Delta t ##, is the surface of a circular conductor loop,d, halved. Calculate the tension, when the surface
  1. is perpendicular to B
  2. has an angular of ##30^\circ## with B
  3. is parallel to B
How I think it could be solved
The magnetic flux
$$\Phi_B = \int_A \vec B d \vec A$$,
where ##\Phi_B## is the magnetic flux, ##B## is the magnitude of the magnetic field and ##A=\pi r^2## is the areal.
The induction tension
$$U_i = \frac{d \Phi_B}{dt} = \frac{\int_A \vec B d \vec A}{dt}$$,
where ##U_i## is the induction tension.
  1. ##U_i = \frac{\sin(90^\circ) A B}{dt}##
  2. ##U_i = \frac{\sin(30^\circ) A B}{dt}##
  3. ##U_i = \frac{\sin(180^\circ) A B}{dt}##
Is that correct? Could it be solved this way?
Questions
Question 1
Can I write it this way?
$$\Phi_B = \int_A \vec B d \vec A.$$
I think it looks wrong, because we have two integrals on the right side and a number on the left side. How could I write it so it doesn't look wrong? I think there are more than one way to write it correct, so please write more than one solution. I think you could use the cross product sign?
Question 2
But now I have solved it the Gaußian way(?). Could I solve it Lorentzian too? I thought of using ##F=q\,\vec v \times \vec B##. The firs formular I suggested is, I think, wrong (it was about the Hall Effect).
Yours Faitfully,
and thank you very much in advance!
BvU
2019 Award
13,367
3,169
Dear Basip,
a quick answer I may have to correct when I'm more awake:
My compliments for your now much clearer post. You have the given variables, the right equation and the right plan to solve. So go ahead !
As to your questions: 1. yes, it is a bit strange, but correct. Check Faraday's law. That ##\vec {dA}## is a surface area .
2. I wouldn't consider this the gaussian way. That has to do with divergence. But in both cases a surface integral is needed.
There is an approach based on the Lorentz force, I think, but I can't investigate now. Check further down in the Faraday link. But it involves more math.
BvU
2019 Award
13,367
3,169
Everything has fallen into place ? And all done ? Or are there further questions ?
Thank you for your help :-)
Related Threads on Induced tension magnetic field (B)
  • Last Post
12K
  • Last Post
