Homework Help: Inductance in DC network
  1. Jan 31, 2013 #1
    1. An inductor of negligible resistance and an inductance of 0.2 H is
    connected in series with a 330 Ω resistor to a 12V d.c. supply.
    Determine:
    (a) the time constant of the circuit
    (b) the voltage drop across the inductor after two time constants
    (c) the voltage drop across the resistor after three time constants
    (d) the resistance of a 0.2 H coil used to replace the inductor if the
    circuit’s time constant falls to 0.55 ms.
    I have calculated A, B, and C, however I am struggling with D.
    (a) 0.606ms
    (b) 1.62V
    (c) 11.4V
    2. Relevent Equations. resistance = inductance / time constant
  3. Jan 31, 2013 #2
    gneill
    Staff: Mentor
    Given the new time constant value, what is the total resistance? (Hint: use the formula you gave as a relevant equation).
    If the external resistor comprises 330 Ω of that total resistance, how much should be ascribed to the new coil?
  4. Jan 31, 2013 #3
    R = 0.2H/0.55ms
    R = 36 Ohms
    Not sure much should much should be ascribed to the new coil, or how this is calculates into the equation
  5. Jan 31, 2013 #4
    gneill
    Staff: Mentor
    That resistance looks a bit too small. Check your units' powers of ten.
  6. Jan 31, 2013 #5
    R = 360 Ohms
    Original Resister = 330 Ohms
    Therefore resistance through the coil = 30 Ohms
  7. Jan 31, 2013 #6
    gneill
    Staff: Mentor
    That looks fine.
  8. Jan 31, 2013 #7
    Cheers gneill thanks a lot mate.
  9. Feb 24, 2014 #8
    Hi guys, sorry to butt in on this post but I am currently completing this question and I'm struggling with b & c. I've worked through the lesson but cannot see any equations that I can use for the voltage drop across the resistor or the inductor. Would either of you be able to point me in the right direction? I've been stuck for a few days now so any guidance would be greatly appreciated. Thanks in advance.
  10. Apr 9, 2014 #9
    The equation you are after is i=I[1-e^-Rt/L] and you will need to calculate I first before you can use the equation
Have something to add?
Draft saved Draft deleted
