Inductance of a solenoid
  1. Nov 25, 2008 #1
    I have to make a solenoid to operate some device. Can anybody let me know what formula to use to calculate number of turns for a solenoid wound on some metal. I also want to calculate the force.
    Does this formula works
    B = uourNI/L
    F = ILB
  3. Nov 26, 2008 #2
    what you are using is for long distance solenoid
    I have seen one more formula
    B=UoUrNI(CosPhi1-Cosphi2)/2l
  4. Nov 26, 2008 #3
    Here is the procedure that I have used to find out the DC solenoid
    v = IR where R is the Dc resistance of solenoid and V is the applied voltage
    R = V/I
    from here I can find out the wire lenght, L from wire table
    now
    F = ILB where F is the weight that solenoid can raise without letting it to fall and L is length of solenoid
    or
    B = F/IL from here I can calculate B
    also B = uourNI/L
    or N = BL/uourI from here I can calculate number of turns
    and inductance = uourN2A/L where A is the cross section area.
    The problem is that if we also consider the inner and outer dia of solenoid and we use some metal material then this crosssection area A correspond to which area. also tell me if F= ILB is the right equation if I want to see how much weight in newton the solenoid can raise if I insert some steel etc object inside solenoid and attach weight F = mg to it and it does not fall down.
