Induction seems to not work?
rock.freak667
6,223
31
Prove by mathematical induction,or otherwise,that [itex]23^{2n}+31^{2n}+46[/itex] is divisible by 48 for all [itex]n \geq 0[/itex]
Assume true for n=N
[tex]23^{2N}+31^{2N}+46=48A[/tex]
[tex] \times (23^2 + 31^2)[/tex]
[tex]23^{2N+2}+31^{2N+2}+46(23^2 + 31^2)+23^2(31^{2N})+31^2(23^{2N})=48A(23^2 + 31^2)[/tex]
[tex]23^{2N+2}+31^{2N+2}+68540+31^{2N}(528+1)+23^{2N}(960+1)=48A(23^2 + 31^2)[/tex]
Simplifying gives me what I need, i.e. things divible by 48, but 68540 is not...any suggestions?
Answers and Replies
Dick
26,263
619
Everything is not supposed to be divisible by 48. You can drop the things that are, of course. Now you just want to show 68540+31^(2N)+23^(2N) gives a remainder of 46 when divided by 48. BTW, it's easier without induction. Just observe 23^2 and 31^2 are both equal to 1 mod 48.
Code:
correct
what's this doing there? if this is a part of the first equation ...
at n+1:
23^(2n)*23^2 + 31^(2n)*31^2+46
now trying writing this in orginal form:
23^(2n)*528 + 23^(2n) + 31^(2n)*31^2+46
do same for 31 ..
since you already got the answer.. here's what I did:
23^(2n)*528 + 23^(2n) + 31^(2n)*960 + 31 ^(2n) +46
= {23^(2n) + 31 ^(2n) +46} + {23^(2n)*528 + 31^(2n)*960}
everything divisible by 48
rock.freak667
6,223
31
Code:
correct
at n+1:
do same for 31 ..
Well I multiplied what I assumed to be true by [itex]23^2+31^2[/itex] so could get [itex]23^{2N+2}+31^{2N+2}[/itex]
wouldn't I need to show that everything is divisible by 48 for it to be true,hence why I can't show 68540 is divisible by 48.
I don't get how I am supposed to show it gives a remaineder of 48, when in the inductive hypothesis, I assumed that everything was together was divisible by 48.
Also,I don't understand what 1 mod 48 means. If it has to do with modular arithmetic,then I definately don't know what you are talking about since I never learnt that.
Over there, from induction you assumed that {23^(2n) + 31 ^(2n) +46} is divisible by 48
at n+1 .. you get {23^(2n) + 31 ^(2n) +46} + {23^(2n)*528 + 31^(2n)*960}
divide this by 48..
23^(2n)*528 is divisible
31^(2n)*960 is divisible...
so everything is proved
rock.freak667
6,223
31
So I am supposed to just substitute n=N+1 instead of building the (N+1)th term?
yep, isn't this is what you do for induction?
first assume it is true for n
and then substitute n by n+1 .. and prove it is true
Dick
26,263
619
You really already have it, you just don't seem to see it. According to your inductive hypothesis, if you divide 23^(2N)+31^(2N) by 48, what is the remainder? Now look at the N+1 case. Assuming the hypothesis what's the remainder of 23^(2N+2)+31^(2N+2) divided by 48?
HallsofIvy
41,847
969
He didn't say "remainder of 48", he said remainder of 46- so that added to the other remainders, they add up to 48.
232= 529= 11(48)+ 1, 312= 961= 20(48)+ 1
So each has a remainder of one when divided by 48.
Also (x+ 1)n= a string of things times powers of x + 1 and so has a remainder of 1 when divided by x. Both 232n and 312n have a remainder of 1 when divided by 48 for any n.
Related Threads on Induction seems to not work?
  • Last Post
