Inductor impedance
Hello, i just want to clarify, is there a difference between the inductor impedance or inductive reactance XL.
inductive reactance XL = 2pi*fL
is this the same for inductor impedance?
i see on an example where they ask you to calculate the reactance in a series RL circuit. V= 100, f= 50Hz, R= 12 and L = 0.1H.
They ask to calculate calculate the reactance and impedance of the coil.
XL = 2pi*fL and impedance (Z) = sqrt(R^2+ XL^2) thats what they use to solve it.
when i check online for inpedance calculator http://www.pronine.ca/indimp.htm they use the inductive reactance formula to calaulate Z.
am a bit confused here, can someone plz clarify some of this. I havent done the lectures for this yet. thanks.
Answers and Replies
The relationship V/I for an inductor and a capacitor is called REACTANCE. It is measured in ohms. The relationship V/I for a resistance is called RESISTANCE.....measured in ohms.
A combination of REACTANCE and RESISTANCE is known as IMPEDANCE....measured in ohms.
The reason for these terms is to identify that V and I are out of phase by 90 for inductance and capacitance whereas V and I are in phase for resistance.
Hope this helps
jim hardy
Dearly Missed
9,847
4,888
i would only add that a PRACTICAL inductor will have some resistance in its windings.
That resistance does not appear in your 2∏fL and must be added to it if you require that accuracy.. which you will in yor coursework.
Related Threads on Inductor impedance
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
