Homework Help: Inelastic ball problem
  1. Oct 11, 2011 #1
    Now the racquet ball is moving straight toward the wall at a velocity of vi = 12.4 m/s. The ball makes an inelastic collision with the solid wall and leaves the wall in the opposite direction at vf = -8.2 m/s. The ball exerts the same average force on the ball as before. Mass of ball =.247 kg
    2. Relevant equations
    What is the magnitude of the change in momentum of the racquet ball?
    3. The attempt at a solution
    so I took
    m*v(initial)=m*v(final) and got 3.0628 and -2.0254 respectively. so I subtracted the two and got -5.0882. I dont feel like this is correct.
  3. Oct 12, 2011 #2
    kuruman
    What is incorrect is to say m*v(initial)=m*v(final) because that is simply not true. It is correct to say that the change in momentum Δ(mv)=m*v(final)-m*v(initial), so if the final momentum is negative and the initial momentum is positive, you end up essentially adding two negative numbers and that's that.
  4. Oct 12, 2011 #3
    PeterO
    Many strange "formulae" and calculations, but probably almost the correct answer.
    Generally change in a quantity means Final - Initial [which you actually ended up doing!!].
    Depending which direction you decide to call positive will mean a final answer of -5.etc, like you got in an unusual way, or +5.etc.
    The question only asked for the magnitude of the change, so the question of a +ve or -ve answer is irrelevant.
Loading...
