Inelastic Collision Problem
In summary, an inelastic collision is a collision where there is a loss of kinetic energy, causing the objects to stick together and move with a common velocity. While the total momentum of the system is conserved in an inelastic collision, the individual momentums of the objects may change due to the loss of kinetic energy. The amount of energy lost in an inelastic collision depends on factors such as the elasticity of the objects, the angle and speed of the collision, and any external forces. The coefficient of restitution, which measures the elasticity of a collision, is equal to 0 in an inelastic collision. An inelastic collision cannot be perfectly elastic, as some of the kinetic energy is converted into other forms of energy.
AntMantis
The figure shows an overhead view of two particles sliding at constant velocity over a frictionless surface. The particles have the same mass and the same initial speed v = 4.00 m/s, and they collide where their paths intersect. An x-axis is arranged to bisect the angle between their incoming paths, so that q = 40.0°. The region to the right of the collision is divided into four lettered sections by the x-axis and four numbered dashed lines. In what region or along what line do the particles travel if the collision is inelastic?
http://www.lowellphysics.org/beta/Textbook%20Resources/Chapter%209.%20Center%20of%20Mass%20and%20Linear%20Momentum/Problems/c09x9_14.xform_files/nw0484-n.gif
Answer:
Here the final speeds are less than they were initially. The total x-component cannot
be less, however, by momentum conservation, so the loss of speed shows up as a
decrease in their y-velocity-components. This leads to smaller angles of scattering.
Consequently, one particle travels through region B, the other through region C; the paths
are symmetric about the x-axis.
How did they get this answer? A step-by-step proof would be greatly appreciated.
Welcome to PF!
Hi AntMantis! Welcome to PF! :smile:
AntMantis said:
Answer:
Here the final speeds are less than they were initially. The total x-component cannot be less, however, by momentum conservation, so the loss of speed shows up as a decrease in their y-velocity-components. This leads to smaller angles of scattering. Consequently, one particle travels through region B, the other through region C; the paths are symmetric about the x-axis.
That answer is really confusing. :redface:
(Is it the official answer?)
If the final paths are symmetric about the x-axis, then their x-components are fixed, the same as the initial x-components.
Since the total energy is less, the y-components must be less … that's all there is to it. :smile:
Except I don't understand why the final paths have to be symmetric. :confused:
Thanks! Yes, that is the answer in the book, which I do not understand. So, does the total x-component have to be the same because the masses are originally traveling with the same x-velocity components? Also, how do I come to the conclusion that the final speeds are less than
they were initially? Is there a way to show this with the law of conservation of linear momentum?
Yes, both the total x-component and the total y-component have to be the same because momentum is always conserved in collisions.
(The total y-component of course is zero.)
Since the x-component is the same, if the y-component was the same or greater, then the total speed would be the same or greater, and so the energy would be the same or greater.
But we know the energy is less. :wink:
The answer is based on the principles of conservation of momentum and conservation of energy in an inelastic collision. In an inelastic collision, some of the kinetic energy of the system is lost to other forms of energy such as heat or sound. This results in a decrease in the final speeds of the particles involved in the collision.
To understand why the particles will travel through regions B and C, we need to look at the x and y components of momentum and energy before and after the collision.
Before the collision, both particles have the same initial speed v=4.00 m/s and the same mass. This means that they have the same momentum in the x-direction, as well as in the y-direction.
After the collision, the total momentum in the x-direction must still be conserved. However, since some of the kinetic energy is lost, the final speed of the particles in the x-direction will be less than 4.00 m/s. This means that the particles will travel at an angle less than 40.0° from the x-axis, resulting in smaller angles of scattering.
In terms of energy, the total energy of the system before the collision is equal to the sum of kinetic energies of the particles. After the collision, some of this energy is lost, resulting in a decrease in the final speeds of the particles. This decrease in speed is reflected in the decrease in the y-velocity components of the particles.
Based on these principles, we can conclude that the particles will travel through regions B and C after the collision. This is because their paths are symmetric about the x-axis and their final speeds will be less than their initial speeds, in accordance with the principles of conservation of momentum and energy.
1. What is an inelastic collision?
An inelastic collision is a type of collision between two objects where there is a loss of kinetic energy. This means that the total kinetic energy of the system before and after the collision is not conserved. In other words, the objects stick together and move with a common velocity after the collision.
2. How is the momentum conserved in an inelastic collision?
In an inelastic collision, the total momentum of the system is conserved. This means that the sum of the momentum of the objects before the collision is equal to the sum of the momentum of the objects after the collision. However, the individual momentums of the objects may change due to the loss of kinetic energy.
3. What factors affect the amount of energy lost in an inelastic collision?
The amount of energy lost in an inelastic collision depends on the nature of the colliding objects and the collision itself. Factors such as the elasticity of the objects, the angle and speed of the collision, and any external forces acting on the objects can all affect the amount of energy lost in the collision.
4. How is the coefficient of restitution related to inelastic collisions?
The coefficient of restitution (e) is a measure of the elasticity of a collision. In an inelastic collision, the coefficient of restitution is equal to 0, meaning that there is no rebound or separation between the objects after the collision. As the coefficient of restitution increases, the collision becomes more elastic and less energy is lost.
5. Can an inelastic collision be perfectly elastic?
No, an inelastic collision cannot be perfectly elastic. In a perfectly elastic collision, the total kinetic energy of the system is conserved, meaning that there is no loss of energy. In an inelastic collision, some of the kinetic energy is converted into other forms of energy, such as heat or sound, resulting in a loss of energy.
