Inelastic Question HELP
  1. Nov 6, 2007 #1
    [SOLVED] Inelastic Question HELP!!!!!!!!!!!!!!!!!!
    A 0.20 kilogram mass is sliding on a horizontal, frictionless air track with a speed of 3.0 meters per second when it instantaneously hits and sticks to a 1.3 kilogram mass initially at rest on the track. The 1.3 kilogram mass is connected to one end of a massless spring, which has a spring constant of 100 Newtons per meter. The other end of the spring is fixed.
    A) Determine the following for the 0.20 kilogram mass immediately BEFORE the impact.
    1. Its linear momentum:
    2. It's kinetic energy:
    B) Determine the following for the COMBINED MASSES immediately AFTER the impact.
    After the collision, the two masses undergo simple harmonic motion about their position at impact.
    C) Determine the amplitude of the harmonic motion.
    D) Determine the period of the harmonic motion:
  3. Nov 6, 2007 #2
    OKAY SO THESE ARE THE ANSWERS I GOT FOR ALL OF THEM.
    PLEASE TELL ME IF THEY ARE WRONG:
    A)
    1) 0.6 kg x m/s
    2) 0.9 J
    B)
    1) 4.5 kg x m/s
    2) 6.75 J
    C) 0.547m
    D) o.77s
  4. Nov 6, 2007 #3
    Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help Help
  5. Nov 6, 2007 #4
    Astronuc
    Staff Emeritus
    Part A is correct. Part B is incorrect.
    For part B, momentum must be conserved, but kinetic energy is not since this is an inelastic collision.
    See - http://hyperphysics.phy-astr.gsu.edu/hbase/inecol.html
    Once the KE for part B is determined, then the deflection of the spring can be determined and that will be the amplitude of the vibration.
    For frequency, the should be straightforward knowing k (spring constant) and m.
  6. Nov 6, 2007 #5
    Thank you, but I still don't get it. I looked at the website and i did what it said but i got the same answers! like i did (m1 + m2)*v and i got 4.5.
    also for the kinetic energy in b, i did what the website said but i got the same answer!
    PLEASE HELP ANYONE!
  7. Nov 6, 2007 #6
    A)
    1) 0.6 kg x m/s
    2) 0.9 J
    B)
    1) 4.5 kg x m/s
    2) 6.75 J
    C) 0.547m
    D) o.77s
  8. Nov 6, 2007 #7
    Please Help!!!!!!!!
  9. Nov 6, 2007 #8
    Please I Really Need Help On This.
  10. Nov 7, 2007 #9
    Astronuc
    Staff Emeritus
    One has to apply conservation of momentum in an inelastic collision. One cannot increase the momentum in the collision! The kinetic energy is not conserved.
    The combined mass cannot be traveling at the same speed! And it certainly will not increase in speed.
    Rather than writing out answers/numbers, please write out one's work, i.e. what forumulas one is using.
  11. Nov 7, 2007 #10
    thank you astronuc!
Similar Discussions: Inelastic Question HELP
Loading...
