1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Inequality problem
  1. Jul 2, 2013 #1
    Find all numbers ##a## for each of which the least value of the quadratic trinomial ##4x^2-4ax+a^2-2a+2## on the interval ##0\leq x \leq 2## is equal to 3.
    2. Relevant equations
    3. The attempt at a solution
    I don't really know what should be the best way to start with this type of question. I started with finding out the roots of the given equation. The roots come out to be
    [tex]x_1=\frac{a+\sqrt{2(a-1)}}{2}, x_2=\frac{a-\sqrt{2(a-1)}}{2}[/tex]
    The roots exist when ##a>1## and it is easy to see that ##x_1>x_2## for ##a>1##. I don't know how to proceed ahead. 0 and 2 should not lie between the roots as we need the minimum value to be 3. Also, ##x_1## is always greater than zero for ##a>1## so 0 and 2 should lie before ##x_1## and ##x_2## on a number line. Hence, the least value will be at ##x=2## and this should be equal to 3.
    [tex]4(2)^2-4a(2)+a^2-2a+2=3[/tex]
    Solving this, I get ##a=5+\sqrt{10}, 5-\sqrt{10}##. Both the values are greater than hence both are admissible but the answer key does not show up the second value i.e ##5-\sqrt{10}##. :confused:
    Any help is appreciated. Thanks!
  3. Jul 2, 2013 #2
    tiny-tim
    Hi Pranav-Arora! :smile:
    You seem to be misinterpreting the question.
    The question isn't about the roots, it's about the minimum. :confused:
  4. Jul 2, 2013 #3
    I understand that the question asks me about the minimum. :smile:
    0 and 2 should not lie between the roots. The given minimum is 3 which is a positive value, and between the roots, the value of quadratic is negative.
    But I am still not sure about how should I begin? What I posted were my thoughts about approaching the problem but I feel that is incorrect. Can I have a few hints? :)
  5. Jul 2, 2013 #4
    tiny-tim
    i'd start by rewriting the original equation in the form (x - b)2 - c2 ≥ 0 :wink:
  6. Jul 2, 2013 #5
    Sorry tiny-tim, there was a typo in the first post, I have corrected it. The correct quadratic is ##4x^2-4ax+a^2-2a+2##, I accidentally wrote -2x instead of -2a. Should I still follow your hint? Sorry for the trouble. :redface:
  7. Jul 2, 2013 #6
    tiny-tim
  8. Jul 2, 2013 #7
    I came up with this: ##(2x-a)^2-2(a-1)## but this doesn't match up with what you asked me. And how did you get that greater than or equal to symbol? :confused:
  9. Jul 2, 2013 #8
    tiny-tim
    and the minimum of that (for 0 ≤ x ≤ 2) is … ? :smile:
    well, we want a minimum, and the question is posed as an inequality problem …
    so i thought it was time to throw in an inequality! :biggrin:
  10. Jul 2, 2013 #9
    ##a^2-2(a-1)##
    :confused:
    Why greater than or equal to zero? Why not greater than or equal to 3? I guess I am missing something really basic. :uhh:
  11. Jul 2, 2013 #10
    tiny-tim
    i preferred to get everything over onto the LHS (and only 0 on the RHS) :smile:
  12. Jul 2, 2013 #11
    haruspex
    2016 Award
    At some stage I think you're going to have to break it into cases. You're looking for the minimum only within the range [0, 2]. In the OP you considered the possibility that the minimum occurs at x=2. You found two values for a that give f(2)=3 , but you did not check whether either of these give f(x)>=3 for all x in [0, 2].
    You also seem to have ruled out other locations for the minimum erroneously. There are two cases to consider for alternative locations of the minimum.
  13. Jul 2, 2013 #12
    tiny-tim, I still do not understand your inequality method but meanwhile, I tried something else and reached the answer but not sure if my approach is correct.
    I had ##(2x-a)^2-2(a-1)##. The squared term is zero when x=a/2.
    Case I:
    ##0 \leq a/2 \leq 2 \Rightarrow 0 \leq a \leq 4##
    For this case, the minimum value is at a/2 i.e ##-2(a-1)##. This is equal to 3 when a=-1/2 but this is not possible as a ranges between 0 and 4.
    Case II:
    When ##a/2 > 2 \Rightarrow a > 4##, the minimum value is at 2.
    Solving the quadratic, I get ##a=5+\sqrt{10}, 5-\sqrt{10}##. Second value is not possible as a is greater than 4.
    Case III:
    When ##a/2 < 0 \Rightarrow a<0##, the minimum value is at 0. From this I get two values ##a=1-\sqrt{2}, 1+\sqrt{2}##. Only the first value is possible.
    Hence, ##a=1-\sqrt{2}, 5+\sqrt{10}##. This is the correct answer however I am unsure about my approach.
    I am still interested in understanding tiny-tim's method.
  14. Jul 2, 2013 #13
    haruspex
    2016 Award
    That looks good. I broke it into cases according to whether the min was at 0, 2, or in-between, but the two methods are pretty much equivalent. I doubt tiny-tim's method was much different either, but it would be interesting to see.
  15. Jul 4, 2013 #14
  16. Jul 5, 2013 #15
    verty
    I believe Tiny-tim was using calculus to get the answer because he had you put it in the best form to apply calculus to solve it. I won't give that method though. As a precalculus question, using the axis of symmetry is the most intuitive way, I believe. And Tim's final formula is the turning point form, so he might well have been hinting that you think about the axis of symmetry or use calculus, which I think is absolutely correct.
    Okay?
Have something to add?
Draft saved Draft deleted
Similar Discussions: Inequality problem
  1. Inequality problem (Replies: 3)
  2. Inequality problem (Replies: 11)
  3. Inequality problem (Replies: 2)
  4. Inequality problem (Replies: 1)
  5. Inequality problem (Replies: 11)
Loading...
