Homework Help: Inertia and Angular Speed
  1. Oct 31, 2013 #1
    A block of mass m = 4 kg hangs from a rope that is wrapped around a disk of mass m and radius R1 = 27 cm. This disk is glued onto another disk of again the same mass m and radius R2 = 66 cm. The two disks rotate on a fixed axle without friction. If the block is released at a height 1.7 m above the ground, what is the angular speed of the two disk system just before the block hits the ground. Answer in units of rad/s
    2. Relevant equations
    Ugrav = mgh
    KErot = 1/2 Iω2
    Idisk = 1/2mr2
    3. The attempt at a solution
    Using the work-energy theorem, the work done on the disks by the block is equal to the final kinetic energy of the block, which is equal to the initial gravitational potential energy of the Earth on the block:
    ΔKblock = ΔUgrav, block = ΔKrot, disks
    Knowing that the final potential energy of the system is approaching zero;
    ΔUgrav, block = mgh
    So far we have:
    mgh = ΔKrot, disks
    Knowing also that the initial rotational kinetic energy of the disks is zero, and with equation I provided, we know that
    ΔKrot, disks = (1/2)Iω2
    Where:
    I = (1/2)mr12 + (1/2)mr22
    The final equation received would be:
    mgh = (1/2)((1/2)mr12 + (1/2)mr222
    cancelling for m:
    gh = (1/2)((1/2)r12 + (1/2)r222
    continuing the move terms over to solve for omega:
    4gh = (r12 + r222
    4 * (9.8) * (1.7) = [(.27)2 + (.66)2] * ω2
    Solving for ω:
    131.05 = ω^2
    ω = 11.45
    This is incorrect though :(
  3. Oct 31, 2013 #2
    NascentOxygen
    Staff: Mentor
    The block gains some KE as it falls.
  4. Oct 31, 2013 #3
    Yep.
  5. Oct 31, 2013 #4
    NascentOxygen
    Staff: Mentor
    The block loses PE. The disks and the block gain KE.
Have something to add?
Draft saved Draft deleted
Loading...
