Exploring Inertia and Gravity in Black Holes: Answering Common Questions
In summary, inertia is the tendency of an object to resist changes in its state of motion. It plays a crucial role in understanding the behavior of objects near black holes, as the immense gravitational pull of black holes can overcome the inertia of objects and cause them to accelerate towards the black hole. The concept of inertia can also explain why black holes have such strong gravitational pull, as their high mass creates a strong gravitational pull that can even affect light. The intense gravity of black holes also causes a significant curvature of spacetime, which affects the path of objects and their inertia. However, the concept of inertia cannot be used to escape the gravitational pull of a black hole, as it is too strong for any object to resist.
string querry
Can anyone answer my amateur questions, and please don't heckle if it seems like a stupid question:
1) Do black holes have a velocity (ie. move within three dimensional space), and if so, does the law of inertia applie to a black hole?
2) Are black holes affected by gravity? (ie. will a large mass traveling toward a black hole tend to slightly pull the black hole towards it as well?)?
3) If the answer to question 2 is affirmative, can two black holes move toward each other and eventual collide, and if so, what would happen? Thanks
Astronomy news on Phys.org
Yes, BHs are just objects with mass in which the mass has gravitationally collapsed in upon itself. Normally they are massive (old stars with MBH > 3 MSun), and can be very massive (MBH > 109MSun), but also it is possible that low mass BHs formed in the vary early universe.
Yes.
Yes, but what happens depends on what else the BHs bring with them.
Two 'naked' BHs will radiate a lot of energy as gravitational waves.
Some BHs are surrounded by an accretion disk of ordinary matter spiraling into them (the model for a quasar engine). If two of these coalesced the ordinary matter would heat up very rapidly and radiate before disappearing into one or both of the BHs event horizons. This model may be the engine for short Gamma Ray Bursts (GRBs) .
Also some of the baryonic matter may be accelerated and thrown out of the system, this scenario may be the source of ultra high energy http://www-mariachi.physics.sunysb.edu/wiki/index.php/Cosmic_Rays, but if so then they would have to be fairly close to the Milky Way (at least <50 Mparsecs and closer for the highest energy CRs). This would require a dense population of BHs throughout the universe.
Garth
Thanks Garth
That helps. The formulas are way over my head but I understand the principles of what you are saying. I figured this was the case, but the Hawking tapes I listened to were riddled with mathematical lingo on this particular issue. I assumed that there is no matter which has no mass and no matter which is unaffected by gravity, but I started to wonder after I read a discussion of whether or not some subatomic particles have no mass at all (it was an old article, and at the time there was, I believe, a general consensus that said particles simply had a mass so inifitely small that it could not be measured). Thanks again.
Additional Question
This discussion lead me to one further question, though it probably lies solely in the realm of the hypothetical: is there anything in the universe that cannot be moved, ie has absolutely no velocity? I suppose this is something akin to "if God can do anything, can God make something so heavy that he can't lift it". Nonetheless, any ideas are welcomed.
That would imply a notion of absolute space, which doesn't exist. If you've got two objects, one 'fixed at the origin' and the other moving in a straight line past it (ie not accelerating), the one which is moving is perfectly allowed to say it's not moving and the one 'fixed at the origin' is moving. It's a matter of your choice of interial frame.
Hence, everything is moving in some frame or other. A super massive black hole would be very hard to move about due to it's enormous inertia but that doesn't mean it's always at rest.
The question would not require absolute space if we consider it as; "is there anything in the universe that cannot be accelerated?". I think this is the idea String was trying to get at.
If that is indeed the question, I would submit that the answer is "no". Accelerating an object becomes more difficult as the object's mass increases. To make an object impossible (or infinitely difficult) to accelerate would require that the object have infinite mass, which no object can have.
No. Give me a lever long enough and a place to stand...
Garth
1. What is inertia?
Inertia is the tendency of an object to resist changes in its state of motion. This means that an object at rest will stay at rest and an object in motion will continue to move at a constant speed and direction unless acted upon by an external force.
2. How does inertia relate to black holes?
Inertia plays a crucial role in understanding the behavior of objects near black holes. As the gravitational pull of a black hole is incredibly strong, it can overcome the inertia of objects and cause them to accelerate towards the black hole.
3. Can the concept of inertia explain why black holes have such strong gravitational pull?
Yes, the immense gravitational pull of black holes is a result of their incredibly high mass. The more massive an object, the stronger its gravitational pull. In the case of black holes, their mass is so concentrated that it creates a strong gravitational pull that can even affect light.
4. How does the curvature of spacetime around black holes affect inertia?
The intense gravity of black holes causes a significant curvature of spacetime, which in turn affects the path of objects and their inertia. This means that objects near a black hole may experience a change in their state of motion due to the curvature of spacetime.
5. Can the concept of inertia be used to escape the gravitational pull of a black hole?
No, the gravitational pull of a black hole is so strong that it can overcome the inertia of any object. This means that even if an object is traveling at a high speed, it will still be pulled towards the black hole and cannot escape its gravitational pull.
  • Astronomy and Astrophysics
