Is Friction the Reason Spinning Tops Eventually Stop Rotating?
In summary, inertia of a spinning top is the tendency of a spinning top to resist changes in its state of motion, and is directly proportional to its mass. The shape and speed of a spinning top can also affect its inertia, with a more compact shape and higher speed resulting in a greater inertia. The inertia of a spinning top can be changed by altering its mass, shape, or speed.
avito009
184
As per Newton an object that is rotating at constant angular velocity will remain rotating unless it is acted upon by an external torque.
But we know that a top will stop rotating after some time. So does that mean that the external torque is the friction of the floor on which the top rotates?
Yes, Because the point of contact between the spinning top and the surface is not an infinitesimal point.
What is inertia of a spinning top?
Inertia of a spinning top is the tendency of a spinning top to resist changes in its state of motion. It is a measure of how difficult it is to change the speed or direction of the spinning top.
How is inertia of a spinning top related to its mass?
The inertia of a spinning top is directly proportional to its mass. This means that a spinning top with a greater mass will have a greater inertia, making it harder to change its state of motion.
Does the shape of a spinning top affect its inertia?
Yes, the shape of a spinning top can affect its inertia. A spinning top with a more compact shape will have a greater inertia compared to a spinning top with a more spread out shape of the same mass.
Can the speed of a spinning top affect its inertia?
Yes, the speed of a spinning top can affect its inertia. A spinning top with a higher speed will have a greater inertia compared to a spinning top with a lower speed of the same mass.
How can the inertia of a spinning top be changed?
The inertia of a spinning top can be changed by altering its mass, shape, or speed. For example, adding weight to a spinning top will increase its inertia, while decreasing its speed will decrease its inertia.
  • Mechanics
  • Mechanics
  • Mechanics
