Inertia Q: Which Frame of Ref Is Inertial?
  • Thread starter endaman95
  • Tags
    Inertia
In summary, an inertial reference frame is one that is not accelerating and for practical purposes, the Earth and the sun can be considered good approximations of this type of frame.
endaman95
Which of the following is an inertial frame of reference when the measuring sensitivity in not very high?
1. A frame of reference fixed to the Sun and its axes are pointing toward 3 other stars.
2.A frame of reference fixed to a laboratory table.
Im not sure about the sun. Any ideas?
Here is my understanding of what is meant by an inertial reference frame:
An inertial reference frame is one that is not accelerating, meaning it is not changing speed or direction.
All frames of reference are, at best, approximations to an inertial reference frame. The sun and the stars in the universe are not fixed and are all moving and accelerating. However, for practical purposes we can assume the Earth and the sun are good enough approximations to an inertial reference frame that we can usually ignore the small inertial forces associated with their movement.
I was thinking the same thing. Thank you for the answer.
Please remember not to do the student's homework for them. It is okay to provide hints, ask questions, suggest search terms, etc. But the student must do the bulk of the work on their schoolwork questions.
As a scientist, my response would be that both frames of reference can be considered inertial in this scenario. Inertial frames of reference are those in which Newton's first law of motion holds true, meaning that an object at rest will remain at rest and an object in motion will continue in a straight line at a constant speed unless acted upon by an external force. In both the frame of reference fixed to the Sun and the frame of reference fixed to a laboratory table, we can assume that the measuring sensitivity is not very high, meaning that the external forces acting on objects in these frames would not be significant enough to affect their motion. Therefore, both frames can be considered inertial in this scenario.
1. What is inertia?
Inertia is the tendency of an object to resist changes in its state of motion. This means that an object at rest will remain at rest, and an object in motion will remain in motion at a constant speed and direction, unless acted upon by an external force.
2. How does inertia relate to frames of reference?
Inertia is a fundamental concept in the study of frames of reference. In an inertial frame of reference, the law of inertia holds true, meaning that objects will behave according to their natural tendency to resist changes in motion. In non-inertial frames of reference, this may not be the case due to the presence of external forces.
3. What is an inertial frame of reference?
An inertial frame of reference is a frame of reference in which the law of inertia holds true. This means that objects will behave in a predictable way - at rest or in motion at a constant speed and direction - unless acted upon by an external force.
4. How do we determine if a frame of reference is inertial or non-inertial?
In general, a frame of reference can be considered inertial if it is not accelerating or rotating. However, there are also specific mathematical criteria that can be used to determine the inertial nature of a frame of reference, such as the absence of fictitious forces.
5. Can an inertial frame of reference be accelerating?
No, an inertial frame of reference cannot be accelerating. This is because acceleration is a change in velocity, and in an inertial frame of reference, objects will maintain a constant velocity unless acted upon by an external force. If a frame of reference is accelerating, it is considered non-inertial.
  • Classical Physics
