Inertial Propulsion
  1. Jan 12, 2009 #1
    In the follow link we are having a discussion about inertial propulsion: http://www.gyroscopes.org/forum/questions.asp?id=994
    Bellow I transcript an open question that I’d like to share with you:
    The question is: How will be the energy conservation in the following experiment:
    “These experiment model is only for model test proposition because the model that I though probably will use gas with plasma or nano particles with super conductor.
    All propulsion systems are based in the rule that to move in one direction we need to push mass in another direction in a linear system, it’s avoid the inertial propulsion.
    What I though? Why the propelled mass need to follow in a linear direction? Why we cannot use particles or small pieces that after fired assume a behavior like a boomerang returning for its starting point? And in order to have a null effect of this principle may we shut the small pieces in the opposite directions with one mass using the other as a support to be fired?
    Then I though: And if we use disks made by diamagnetic material allowing the floatation without any contact. One disk turning in an opposite direction of other. The disks may have teeth like small ramps. When one of disk touches the other, due the high rotation the teeth send them for opposite directions. A mechanical device may be used in each disk to change its form when this shut happens; we may change the disk form to allow it turn out of mass center helping to create the angular trajectory.
    What do we will have: 2 masses propelled one against to other moving with its inertial energy in an angular (non linear trajectory), for same side and inside of an box or chamber. But instead of these 2 disks return for its start point, in the middle way they will collide with chamber wall transferring its energy.
    The big jump will be the usage of superconductor material to break the physical connection. The disks that will float free may be accelerate magnetically without physical contact. To feed the system again, the disk may loose its diamagnetic condition by using a laser and falling in feedback mechanisms.
    I’m trying to identify if with this new materials I found a breach in the energy conservation rule or if I’ missing some thing!
    Again thank you from a friend in the other side of planet!”
  3. Jan 12, 2009 #2
    You cannot break the first law of thermodynamics, no matter how many hi-tech devices or how much techno-jargon you use. Sorry.
  4. Jan 12, 2009 #3
    Staff: Mentor
    Welcome to PF, Gitirana. Please reread the PF guidelines: we deal only in real physics here. Claims that explicitly violate such well established principles as the first law of thermodynamics are crackpottery and not allowed here.
Similar Threads - Inertial Propulsion Date
Real IC Engine Inertial Data? Jan 30, 2018
Centrifugal propulsion Jan 11, 2018
Reynolds numbers and inertial force Nov 13, 2012
Aerospace Can any one explain Schuler cycle in Inertial Navigation System Dec 1, 2011
Aerospace Inertial Navigation Integration FIlter Mar 14, 2011
