Inexpensive Mid Engine Transaxle
  • Thread starter average guy
  • Tags
    Engine
In summary, an inexpensive V8 mid engine transaxle can be used to build a 200 MPH sports car. A small block Chevy engine and powerglide transmission can be used, along with a coupler and Corvette IRS 3rd member. This combination is the best option for anyone who wants to build something not the same old- same old.
average guy
119
Inexpensive V8 Mid Engine Transaxle
if any of you want to build a 200 MPH sports car in your spare time
take a small block chevy engine + powerglide transmission ( their short )
+ a coupler ( connects trans right to rear end, no driveshaft ) +
Corvette IRS 3rd member ( their cheap now, old cast iron one will do )
= mid engine drivetrain for anybody that wants
to build something that's not the same old- same old
small block chevy is ok..powerglide is not the hot set up for a sports car..vette independent rear is..solid axle is not
but..its nailing this combo togeather and proper suspension,,thats the hairy part
Small-block Chevy is definitely the ticket to dependable power on demand. A friend of mine is a drag-racer, and he got into Mopar back during his stint in VietNam, sending all of his pay back to his father, to buy a 340 Duster. He had to work his butt off to beat the Chevy small-blocks in his class(es), because they could make impressive HP on demand. We spent a lot of time talking about this while driving to drags in NH or NB, and he thought the main problem in competing was that the pistons, rods, etc were so much lighter in the Chevy engines. He used to borrow my Dremel tools back when he lived in a trailer to grind the skirts off his pistons to lighten them (crude but effective).
After a couple of his runs at Epping, spectators would buy pit-passes just to come look at his car and talk to him. Almost to a person, they thought that he had shoehorned a big-block Hemi into that Duster because it could pull impressive wheel-stands. By the time they got to the pits, the hood was off to the side, and we were replacing the coolant with fresh water (one of his tricks for consistency in bracket-racing) and they were amazed to see a 340 in the engine compartment.
Still, old Chevys with small-blocks ruled those tracks back then.
Turbo..you nailed it..i am the huge Mopar fan..
SB Mopars were in fact lighter than a similar SB Chevy..but they had huge design flaws..the mopar deck was only 3/8 thick and only 4 bolts surrounded each piston vs 5 on the SBC
so blown head gaskets were serious problem over 11-1 compression ration..
they had oiling problems too.. had to do major plumbing to oil the con rod bearings..the weird intake ports limited the total horsepower until you did serious rework in this area too.
if you O-ringed the block , you could get real close numbers to the SBC and with slightly less weight. Dont forget the SB mopar was introduced in 1964 about 9 years after the SBC and had thin wall casting design..looked good on paper but took a lot of rework to perform..had good rod to bore ratio...
Some race cars actually have to have fenders. :devil: Or they can't compete in their classes.
BTW, Steve used to look for used engines in (or in back of) barns, etc. His philosophy was that unless an engine had been run hard and subjected to temperature extremes like here in Maine, he didn't want to put time and money into re-building it. I think his record speaks for itself. Smart guy!
o h the days of do it your self racing!
great video...yep..seasoned engine block is a must..and torque plate when boring it..
most excellent Christmas present Turbo!
My younger cousin wrecked his "Little Red Wagon" pickup soon after buying it. I didn't know that the truck has been taken for salvage until a bit later, and Steve was so disappointed when I told him. Those truck engines were fitted with W2 heads, and getting those could have saved him a bunch of time, effort, and money. Lots of head-work involved in getting those small-block Mopars to perform.
I should mention that the wheelie-bars were added to avoid catastrophic failure due to oil-pan destruction. Heavily-loaded front shocks weren't enough after he got that car performing like he needed.
ranger mike
no big deal building one of these
about the same work as a bucket t just different
where there's a will there's a way
yes a mopar or fomoco drivetrain could be used
if the tranny has a 'dragster' tailshaft available that helps keep it short
torqueflites have one but they're rare
powerglides have a lot of versions that are already short and
there's a dragster tailshaft ( it's really just a cap to hold bearing )
i think mopars are great but better to go with the flow on this one
Good idea..my thinking on powerglide was related to the original post..sports car..and for a road course you need at least 4 speeds..but..for a street rod..two is just fine..i would check out a hewland trans axle set up..many ate available for SBC..
i got NO doubt you can get her done!
ranger mike
here's the link for the couplers
http://www.swracecars.com/store/Couplers--Splined-Driveshaft-Parts-OSCAR_182.aspx
regarding powerglides
the race rebuilders have gone a long way with these
as far as i know it's still a 2 speed but
the race units can handle huge amounts of power
but for a low budget build a stock one will work fine
with small block chevy
quick social responsibility note:
these cars has gas tank either next to driver or
up in front if this isn't for you don't do it
One nice sunny day I went to the Lakewood theater complex (very pretty setting) to take some promotional shots of his car. We rolled it off the trailer, got some pix, and then he started it up and drove it back onto the trailer. A very curious older couple who owned a cottage in that complex came wandering around to see what was going on, and the lady said something like "is that car broke?" because it was pretty noisy, even at idle.
Another little story - At the Winston Cup races at Epping, I was taking pictures from the starting line (I could get track passes for photography) and something went horribly wrong on launch. He had an easy draw in the quarter-finals and broke. By the time I made my way down to the far end of the pits, the Brut funny-car mechanical team had torn down the top-end of that 340 to see what had happened. Intake valve had shattered and re-distributed pieces of itself all through the engine. They buttoned it up and helped us push it back down to the other end of the pit and push it up on the car-carrier. It was so nice to see an amateur get such respectful treatment from a team of pros.
Turbo
you just described why i have been involved in racing since 1966
Racers can not race unless they have some one to race against so just about all racers pitch into assist each other when that can.., even the top end teams who all started from humble beginnings..there are always horses Arse types but that goes for all walks of life..seems like i prefer to hang out with racer types ...
one time 3 years ago the racer who was leading us by one race win, broke at the track..I had the only tools and parts available ..he was racing the same model Reynard..
we got him running, he made the race..
some would say this was a stupid move...
my driver and i knew it was the right call...
same in life...
ranger mike
you can keep the grey poupon
and your little self awarded halo
you can keep the pantera transaxle too
if your trying to play it off like your
another briggs cunningham tell it to someone else
i'm extremely busy going extremely fast
got a question for you?
how many seats in a race car?
you want to be on a team go play football
Errrm there's no need for that now is there? Take it somewhere else.
Nice story Ranger, it's just the same here with sprinting and hillclimbing. You're genuinely pleased to see your competitors doing well. We have lent and borrowed tools and tyres and even had the very kind offer of an axle once, even though that would have meant taking it off his competing car!
Yep! There was a Canadian dragger that was really pushing the limits (Camaro launching at over 10K) and some people at the drags were willing to help out when he broke and needed to rebuild the clutch at Pennington NB, even if it allowed him to kick their butts.
Scary-good car in the 80's. Not as impressive as Steve's consistent improvement and performance, IMO, but really hot for the time.
brewnog
i'm one of the first one's to go help somebody but
i just don't like snotty comments
who does?
the TH350 and TH400 have a dragster tailshaft and
i forgot to mention it takes a shorter splined shaft
the usually come with it
happy holidays
Not all mid-engine applications have as much fore and aft room as a Corvair.:wink:
mender
you get an 'A' for actually responding to subject of post
corvair and aircooled VW are nice choices
the price drop for the corvette IRS rear ends
makes it reasonable now to build a V8 midengine
plus yours truly finally catching on about those couplers
the powerglide is 'get it done' choice
1 automatic-no routing Formula Vee type manual shifter linkage
2 it's short and easy to find
happy holidays!
turbo said:
Those truck engines were fitted with W2 heads ...
No; only the test mule got a set of those, the production models had production heads.
And as has been said many times, SBCs weren't the best engines, just the cheapest; there were other engines that had more potential including the small block Mopars but the good parts were much more expensive.
hi
1- I need to installed the waste heat recovery boiler on the engine exhaust (engine 1 MW , 1500rpm, exhaust temp 500'C) what capacity of boiler can be installed and how i calculate the size of boiler
2 - how to convert the engine exhaust in kw of energy ,and how can i calculate the amount of energy lost by the engine in terms of flue gas
3- I want to used the engine jacket water temperature for chiller how can i calculate the amount of energy obtain from the jacket water
rtakhan said:
hi
Welcome to PF, Rtakhan.
Since this is a bit off-topic from the original thread, I would suggest that you start your own with this particular topic in mind.
1. What is an inexpensive mid engine transaxle?
An inexpensive mid engine transaxle is a type of transmission that is located in the middle of the vehicle, between the engine and the rear wheels. It is known for its compact design and efficient power transfer, making it a popular choice for sports cars and high-performance vehicles. The "inexpensive" aspect refers to its lower cost compared to other transmission options.
2. How does an inexpensive mid engine transaxle work?
The transaxle connects to the engine through a drive shaft and uses gears to transfer power to the wheels. It also houses the differential, which distributes power to the wheels at different speeds, allowing for smooth turns and handling. The mid-engine placement helps to evenly distribute weight and improve balance and handling of the vehicle.
3. What are the benefits of using an inexpensive mid engine transaxle?
Some benefits of using an inexpensive mid engine transaxle include improved performance, better weight distribution, and increased fuel efficiency. The compact design also allows for more space in the front and rear of the vehicle, making it easier to accommodate other components or features.
4. Are there any drawbacks to using an inexpensive mid engine transaxle?
One potential drawback is that the transaxle may not be as durable as other transmission options, especially in high-performance vehicles. It may also be more difficult and expensive to repair or replace. Additionally, the mid-engine placement may limit access for maintenance and repairs.
5. How does an inexpensive mid engine transaxle compare to other transmission options?
Compared to front or rear-engine transmissions, an inexpensive mid engine transaxle offers better weight distribution, improved handling, and increased efficiency. However, it may not be as strong or durable as other options and may require more maintenance and repairs. Ultimately, the best transmission choice depends on the specific needs and goals of the vehicle and its owner.
  • Mechanical Engineering
21K
  • Science Fiction and Fantasy Media
50K
  • Thermodynamics
