Does the Symmetry of f(x)=1/x Imply Equal Rates of Approach to Infinity?
In summary: I dunno... thing to confuse over.In summary, the function f(x) has an inverse function of f(x) which implies that when x<1, f(x) approaches \infty as fast as f(x) approaches 0 when x>1. However, if x<1, the area between the lines y=x and y=-x is not finite.
Beam me down
47
Let [tex]f(x)=\frac{1}{x} , x \geqq 0[/tex]
[tex]\therefore \int_{0}^{\infty} f(x) dx = \infty[/tex] (1)
However the function f(x) has an inverse function of f(x), ie. the function f(x) when m,irrored around y=x is the same shape. Does this imply that when x<1 f(x) approaches [itex]\infty[/itex] as fast as f(x) approaches 0 when x>1?
If so wouldn't:
[tex]\int_{0}^{\infty} f(x) dx = 2 \times \int_{1}^{\infty} f(x) dx (2)[/tex]
I understand mathematically that (1) is correct, but when I think about the areas logically I can't understand how lines that approach the respective axis at what appears to me to be the same rate can have one part (x>1) with a non-infinite area and yet have a part ([itex]0 \leqq x < 1[\itex]) which has an infinite area.
First, the regions that should have the same area (in an imprecise way, since you can't compare infinite quantities) are the areas separated by the line y=x, so your integral is slightly off (missing the triangle from (0,0) to (1,0) to (1,1)). Second:
[tex]\int_1^\infty \frac{1}{x} dx = \ln(x)|_1^\infty = ln(\infty)=\infty[/tex]
So this does not have a non-infinite area.
Yes, that's true. If fact, if f(x)= 1/x and g(x)= f-1(x) then
f(x)/g(x)= 1 for all x so they go to infinity at exactly the same "rate".
If so wouldn't:
So you are saying [itex]\infty= 2\times\infty[/itex]? That's true is the extended real numbers in which you can do "arithmetic" on "infinity" but not the regular real numbers.
I understand mathematically that (1) is correct, but when I think about the areas logically I can't understand how lines that approach the respective axis at what appears to me to be the same rate can have one part (x>1) with a non-infinite area and yet have a part ([itex]0 \leqq x < 1[/itex]) which has an infinite area.
?? What?? Why would you say that for x>1 the area is "non-infinite"?
[tex]\int_1^\infty \frac{1}{x}dx= \infty[/tex]
also.
In fact,
[tex]\int_a^\infty \frac{1}{x}dx= \lim_{x\rightarrow\infty}ln(x)- ln(a)= \infty[/itex]
and
[tex]\int_0^a \frac{1}{x}dx= ln(a)- \lim_{\epsilon\rightarrow 0} ln(\epsilon)= \infty[/tex]
Beam me down said:
[tex]\int_{0}^{\infty} f(x) dx = 2 \times \int_{1}^{\infty} f(x) dx[/tex]
This is true anyway since as mentioned both sides are infinite, but geometrically the argument would go
[tex]\int_{0}^{\infty} f(x) dx = 2 \times \int_{1}^{\infty} f(x) dx + 1[/tex]
because of the unit square that is not included when you integrate from 1 in the x or y direction.
Well... I think what you're saying is that isn't it the same to sum up 1/x from 1 to infinity as it is to sum up 1/x from 0 to 1. Hmm, I think the main problem here is that when you are summing up terms from 1 to infinty you never encounter infinite numbers, whereas if you were summing from 0 to 1 you would (the infinitely small region dx times the height at 0, infinity--technically undefined I guess, which also might be why). I'm pretty sure that this is the main reason you can't, because you can't add infinity.
No, what he wants to say is that it's the same to sum 1/x from 1 to infinity as it is to sum 1/x from 0 to 1 and then subtract one. Also, just because the height at 0 is infinite doesn't necessarily mean you can't define an integral- you can define the integral as the limiting case as you get closer to 0. Everything about the geometric argument would be stated the same yet deal with finite values if you let f(x) = 1/x2 instead.
Oh, I see what he's saying now, so... what is wrong with his argument?
The only thing wrong with the argument is that infinity is not a real number and, even in number systems in which "infinity" is defined, it doesn't satisfy the usual rules of arithmetic.
I understand that infinity is not a real number.
I was looking at the rate at which 1/x approaches either axis, but I was thinking of 1/x^2 when working with the integrals (which does have a real definite integral for the lower bound=1 and the upper bound =infinity) so I made a fundamental mistake.
But the graph of [itex]\frac {1}{x^2}[/itex] is not symmetric about y=x so does not approach the y-axis and x-axis at the same rate, which clears up my understanding of why [itex]\int_{0}^{1} \frac {1}{x^2} dx \neq \int_{1}^{\infty} \frac {1}{x^2} dx[/itex]. It was just a confusion with the exponential and seems to be such a silly mistake.
1. What is the meaning of an infinite area in the graph of f(x)=1/x?
The infinite area of the graph of f(x)=1/x means that as x approaches zero, the area under the curve also approaches infinity. This is because as x gets smaller, the value of 1/x gets larger, leading to an unbounded area under the curve.
2. How is it possible for an area to be infinite?
An area can be infinite if the function being integrated has no upper bound or limit. In the case of f(x)=1/x, as x approaches zero, the function becomes unbounded and thus the area under the curve also becomes unbounded.
3. What is the practical significance of an infinite area?
An infinite area can have practical significance in certain mathematical and scientific applications. In the case of f(x)=1/x, the concept of an infinite area helps us understand the behavior of functions that approach infinity or have asymptotes.
4. Can we calculate the exact value of an infinite area?
No, we cannot calculate the exact value of an infinite area. However, we can approximate it by using techniques such as limits and Riemann sums.
5. Does an infinite area always indicate a mathematical error?
No, an infinite area does not always indicate a mathematical error. In certain cases, such as f(x)=1/x, the infinite area is a result of the behavior of the function and is a valid mathematical concept.
