Maximizing Capacitance: Solving an Infinite Capacitor Chain Problem
In summary, an infinite series of capacitors with a capacitance of 6.34 mF has an equivalent capacitance of 6.34 mF.
Vanessa23
41
[SOLVED] Infinite capacitors
Consider the infinite chain of capacitor problem:
Each of the capacitors (C) below in the infinite series circuit has a capacitance of 6.34 mF. What is the capacitance of a single capacitor that can be connected between points A and B to replace the “chain”? (The picture of the capacitor should be attached to this thread)
Then the real question:
suppose that each of the capacitors in the chain has a capacitance of 21-mfarads. What is the equivalent capacitance of the infinite chain?
a hint: 5 = [x + {x + (x + . . . )1/2}1/2]1/2
Solve for x: x = 20
Q=CV and CT=C1+C2+C3 for parallel chains but capacitors in series
add as 1/CT=1/C1 + 1/C2 + 1/C3
For the first part, it would have to be equal to 3 parallel capacitors in series with 4 capacitors, which I assume is where the hint comes from.
I am assuming that the x=20 means that there are 20 xs in the equation? and that you solve for x, but then why do you never take into consideration the 6.34mF?
or is the hint for the second part of the problem?
We have the same problem. i think i got it. take two capacitors on end, in parallel with each other, so they add, c + c = 2c [they are all the same c]. now the parallel ones become one capacitor of 2c. now take the next two [opposite each other and in parallel], and do the same thing, you now have another equivalent capacitor value of 2c. now these two are in series, so to get series equivalent, 1/c = you add 1/2c + 1/2c = 2/2c or 1/c, so c = c, which they told us [a hint] in our problem was the answer. in other words the equivalent capacitance of an infinite series of capacitors of 6.34 mF is 6.34 mF.
This doesn't make sense at all. There are no 2 capacitors that are parallel in this circuit. Parallel doesn't mean drawn parallel, it means that both sides of each capacitor are connected to each other.
In order to compute this: suppose that the capacitance of the whole circuit is X. this capacitance doesn't change if you add one more section at the beginning. compute the capacitance of the circuit in which you replace all but the first section of 3 capacitances with a capacitance X. This capacitance should be equal to X.
You'll end up with a quadratic equation for X, which has one positive root. (X depends on c of course)
1. What is a capacitor chain problem?
A capacitor chain problem is a theoretical problem that involves connecting an infinite number of capacitors in a series, with each capacitor having a different capacitance value. The goal is to find the maximum capacitance of the entire chain.
2. Why is it important to maximize capacitance in a capacitor chain?
Maximizing capacitance in a capacitor chain is important because it allows for more charge to be stored in the chain, increasing its energy storage capacity. This can be useful in various applications, such as in electronic circuits or power grids.
3. What is the formula for calculating the maximum capacitance in an infinite capacitor chain?
The formula for calculating the maximum capacitance in an infinite capacitor chain is C = C1 + C2 + C3 + ..., where C is the maximum capacitance and C1, C2, C3, etc. are the individual capacitance values of each capacitor in the chain.
4. How do you solve a capacitor chain problem with a finite number of capacitors?
To solve a capacitor chain problem with a finite number of capacitors, the capacitors can be connected in series or parallel to create an equivalent capacitance. Then, the maximum capacitance can be calculated using the same formula as an infinite capacitor chain.
5. Are there any practical limitations to maximizing capacitance in a capacitor chain?
Yes, there are practical limitations to maximizing capacitance in a capacitor chain. In real-world applications, there are limitations on the size and material of capacitors, as well as the maximum voltage they can handle. These limitations can affect the overall capacitance that can be achieved in a capacitor chain.
12K
