Homework Help: Infinite/Finite Set Proof
  1. Aug 4, 2013 #1
    Let S be in finite and, A a subset of S be finite.
    Prove that that the cardinality of S = the cardinality of S excluding the subset of A.
    2. Relevant equations
    3. The attempt at a solution
    We can write out the finite subset A as (x1, x2, ... xn) which can be put into a one to one correspondence with N. S is infinite so a bijection to N is not possible by definition. The cardinality of S excluding A is still uncountable but I don't see why they MUST have the same cardinality.
  3. Aug 4, 2013 #2
    I know to show cardinalities are equal I need to be able to construct a bijection between them...
    Bijection between two infinite sets seems confusing.
  4. Aug 4, 2013 #3
    LCKurtz
    Start with something simple. Do you see how to make a bijection between the natural numbers ##\mathbb N## and ##\mathbb N## excluding {1,2,3,4,5,6,7,8,9,10}? It's the same idea.
  5. Aug 4, 2013 #4
    Sure I'd map 1 from the first set N to say 11, map 2 to 12, 3 to 13....
    My bijection would be for n in N (the fully inclusive N) f(n) = n+ 10?
  6. Aug 5, 2013 #5
    LCKurtz
    Sure. Now can you figure out how to use that kind of thinking for your original problem.
  7. Aug 5, 2013 #6
    I guess how I would write it is problematic for me, I understand your idea, take that excluding set A, which is a set from x1 to xn and begin the mapping from a xn + 1. But how do I know my excluded set is ordered, and how do I know that the numbers are consecutively equally spaced the set from 1 to 10 is easy to visualize as an example. But this random set A seems like it could cause problems for the function I would have to write if it isnt as simple.
    Or does what I mention even matter when writing a bijection?
  8. Aug 5, 2013 #7
    LCKurtz
    You're right, the set in your problem isn't ##\mathbb R##. But it's the idea that counts. Can you find an infinite sequence of distinct points from S where the first N terms of the sequence are the points from A (which has only N points) and the rest are not from A? Then....
  9. Aug 5, 2013 #8
    vela
    Staff Emeritus
    Education Advisor
    You seem to be assuming S is uncountable, but is that really the case? In the problem statement, you simply say S is infinite, so you need to make sure your argument works for both the countably infinite and uncountably infinite cases.
Have something to add?
Draft saved Draft deleted
