Infinite geometric series
  • Thread starter Pual Black
hello this question is discussed in 2009 but it is closed now
If you invest £1000 on the first day of each year, and interest is paid at 5% on
your balance at the end of each year, how much money do you have after 25
years?
## S_N=\sum_{n=0}^{N-1} Ar^n##
where N is the last term
r is the common ratio & A is a constant
## S_N= a\frac{1-r^N}{1-r} ##
after 25 years i would set N=25 but this will give me a result of £47727. then i have to subtract £1000 because on the first day of each year i invest £1000 therefore i got a result of £46727
but this is the wrong answer
if i set N=26 i will get £51113 and then again subtract £1000
therefore i got a result of £50113 and this is the right answer
my question is why i must put N=26. isn't N the last term and equal to 25?
and is this way of solution right?
Answers and Replies
BvU
14,401
3,712
Can't follow your equations. "N is the last term"? Wouldn't N be the number of terms/years ?
And then after one year you don't have ##Ar^0## but ##Ar^1##.
Tip: Don't change the notation from one line to the next. A is A, not a.
## S_N= A\frac{1-r^N}{1-r} ## looks weird too. Don't you mean ##
S_N= Ar\frac{\ 1+r^N}{1+r}## so that after 1 year you do have Ar ?
Ray Vickson
Dearly Missed
10,706
1,722
No, his formula is correct as written: ##\sum_{n=0}^N A r^n = A(r^N -1)/(r-1)## is a standard elementary algebra result. Of course, it also equals ##A(1-r^N)/(1-r)##.
ehild
15,543
1,912
If you sum from 0 to N, it is N+1 elements. The correct formula is ##\sum_{n=0}^{N-1} A r^n = A(r^N -1)/(r-1)##
Ray Vickson
Dearly Missed
10,706
1,722
If you sum from 0 to N, it is N+1 element. The correct formula is ##\sum_{n=0}^{N-1} A r^n = A(r^N -1)/(r-1)##
Indeed: that was a typo on my part. I had intended to make the upper summation limit equal N-1, but somehow slipped up.
BvU
14,401
3,712
Sorry for the minus sign - weak moment.
Time to define what A stands for. My impression was that after one year the guy has ##Ar##, not ##
\sum_{n=0}^{0} A r^n = A(r^1 -1)/(r-1) = A##
Time to define what N stands for, too: at the begining of year 2, they guy has
\sum_{n=0}^{1} A r^n = A(r^2 -1)/(r-1) = A(r+1)## and he invests another A ?
I figured r = 1.05 and A = 1000 pounds. Where did I go all wrong ?
$$1000 \,{1.05^{26} - 1\over 1.05 -1} = 51113.45 $$
$$1050 \,{1.05^{25} - 1\over 1.05 -1} = 50113.45 $$ which OP considered the right answer .
The
all variables and given/known data
in the template is clearly useful. And includes the list of what values in the problem statement the symbols used stand for ...
:smile:
yes you are right N is the number of terms
and i get it now. first i invest £1000 so i have nothing at this moment after one year i have £1000*1.05= £1050
so i start with £1050=Ar
Ray Vickson
Dearly Missed
10,706
1,722
Easier: just write it out correctly from the start. If ##r = 1.05##, ##A = 1000## and ##N = 25##, the value you want is the "future value" ##F##:
[tex] F = A r + A r^2 + \cdots + A r^N = A r \sum_{n=0}^{N-1} r^n [/tex]
Basically, the final ##A## at the start of year 25 becomes ##Ar## at the end of year 25. The second-last ##A## at the start of year 24 becomes ##A r^2## at the end of year 25, and so forth.
Likes Pual Black and BvU
Related Threads on Infinite geometric series
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
