Infinite Loop problem in an array sorting program
In summary, an infinite loop in an array sorting program occurs when the program gets stuck in a continuous loop without ever terminating. This can happen due to logic errors, incorrect termination conditions, or unexpected input. To prevent an infinite loop, thorough testing and debugging is necessary, along with using proper termination conditions and avoiding logic errors. If a program is stuck in an infinite loop, it is important to identify the cause and seek help from colleagues or debugging tools if needed.
scothoward
29
Hi, I am writing a function that takes in a real data array and a key partition value, which will rearrange the array so that elements with a lower value than x are placed before the elements with values >= the partition value. It then returns the index of the last element of the array with a value less than the partition value.
We were given some pseudo-code which uses the idea that we start from the left and right and simultaneously switch elements using two loops excited together.
CODE
Code:
integer function partition_data( xdata, xmiddle )
    implicit none
   real, dimension(:) :: xdata
   real :: xmiddle !INTENT?
   integer ::  l = 1
   integer ::  r = 16
   real :: temp
    do
       if (xdata(l) < xmiddle) then
          if (l == r) then
             partition_data = l
             exit
          end if
             l = l + 1
       else
          do
             if (xdata(r) >= xmiddle) then
                if (l == r) then
                   partition_data = l - 1
                   exit
                end if
                r = r - 1
             else
                temp = xdata(l)
                xdata(l) = xdata(r)
                xdata(r) = temp
                exit
             end if
          end do
       end if
    end do
  end function partition_data
With the xdata array
xdata = (/ 0.00392, 0.0251, 0.453, 0.667, 0.963, 0.838, 0.335, 0.975, &
0.796, 0.833, 0.345, 0.871, 0.0899, 0.888, 0.701, 0.735 /)
The xmiddle was set to 0.5 in the main test program.
When I compile, I seem to get an infinite loop and I cannot find where it is.
If anyone can spot where I went wrong, that would be great.
Thanks in advance!
Technology news on Phys.org
The OP hasn't been around for years, but in case others are interested, here's what I found. I implemented the code shown above in C++, and it worked without any problems. After the partition function returned, the array was ordered with all of the elements < 0.5 appearing before all those that were >= 0.5. The only changes I made were to replace the initial values of l and r with 0 and 15 respectively, since arrays in C/C++ are zero-based.
Without seeing the code you actually wrote, it's impossible to say why your code goes into an infinite loop.
My code:
C:
int partitionData(float xdata[], float xmiddle)
    int l = 0, r = 15;
    float temp;
    while (1)
        if (xdata[l] < xmiddle)
            if (l == r) return l;
            l++;
        else {
            if (xdata[r] >= xmiddle)
                if (l == r) return l - 1;
                r--;
            else
                temp = xdata[l];
                xdata[l] = xdata[r];
                xdata[r] = temp;
The partitionData() function returned 5.
Output with xmiddle set to 0.5. :
Code:
0.00392
0.0251
0.453
0.0899
0.345
0.335  << index 5, the last element of the array whose value is < xmiddle
0.838
0.975
0.796
0.833
0.963
0.871
0.667
0.888
0.701
0.735
Likes sysprog
What is an "Infinite Loop" in an array sorting program?
An infinite loop is a situation where a program gets stuck in a continuous loop, repeating the same set of instructions over and over again without ever terminating. This can happen in an array sorting program if there is a logic error or incorrect termination condition, causing the program to endlessly sort the same elements.
How do I know if my array sorting program is stuck in an "Infinite Loop"?
If your program is taking a long time to execute or not producing any output, it may be stuck in an infinite loop. You can also check the CPU usage of your program, and if it is consistently at 100%, it is likely caught in an infinite loop.
What causes an "Infinite Loop" in an array sorting program?
An infinite loop can be caused by a variety of factors, such as incorrect logic, incorrect termination condition, or errors in the code. It can also be caused by unexpected input or data that the program is not equipped to handle.
How can I prevent an "Infinite Loop" in my array sorting program?
To prevent an infinite loop, it is important to thoroughly test and debug your code to ensure that all possible scenarios and inputs are accounted for. Using proper termination conditions and avoiding logic errors can also help prevent an infinite loop from occurring.
What steps should I take if my array sorting program is stuck in an "Infinite Loop"?
If your program is stuck in an infinite loop, the first step is to try and identify the cause of the loop, such as a logic error or incorrect termination condition. You can also try to interrupt the program or restart it. If all else fails, seeking help from a colleague or debugging tools can assist in finding and resolving the issue.
