Homework Help: Infinite Series & Limits
  1. May 8, 2007 #1
    1) Determine whether the infinite series
    Sigma (k^2-1) / (3k^4 + 1)
    k=0
    converges or diverges.
    [My immediate thought was to use the "limit comparsion test", but this test requires all terms to be positive. However, the first term (put k=0) is definitely negative...what should I do? Can I still use the limit comparsion test, and if not, what other tests can I use?]
    2) Evaluate
    lim [t^2 - t^3 sin(1/t)]
    t->∞
    [When I direct substitute, I get ∞-∞*0, and I have no clue how to solve this problem...any hints?]
    Thank you for your help!:smile:
  3. May 8, 2007 #2
    let [tex]a_{n} = \frac{k^2 - 1}{3k^4 + 1}[/tex]
    and [tex]b_{n} = \frac{1}{k^2}[/tex]
    then show that [tex]a_{n} > b_{n}[/tex] for every n
    Okay, I finally got it...
  4. May 8, 2007 #3
    But if an>bn and bn converges, it tells you nothing whether an converges or not...how does that help?
    And also, it doesn't look very straight foward to me to prove that an>bn
  5. May 8, 2007 #4
    1) Also, I am still wondering whether I can apply "limit comparsion test" to this problem or not...does anyone know?
    Thanks!
  6. May 8, 2007 #5
    Office_Shredder
    Staff Emeritus
    This is where convergence is beautiful. It doesn't matter if the first term is negative; just look at the sum
    term one + series starting from term two.
    Clearly this sum exists iff your original series converges (if that's not obvious, prove it)
    BTW, I think [tex]a_n<b_n[/tex] as posted above, because [tex]a_n[/tex] approximates [tex]\frac{1}{3k^2}[/tex]
    (in fact, it's always less than that.... you should be able to show that too)
  7. May 9, 2007 #6
    So when I am trying to see whether an infinite series converges or diverges, I can always change the lower index of summation whenever I want?
    an approximates 1/3k^2, but how can I know which one is larger?
    Thanks!
  8. May 9, 2007 #7
    quasar987
    That's right; convergence or divergence of a series is independent or the starting index.
