Solve Sum of Infinite Series: cos(n*pi)/5^n
In summary, the question posed is to find the sum of the series \sum(cos(n*pi)/5^n) from 0 to infinity. It is proven to converge using the ratio test, with the limit approaching -1/5 as n goes to infinity. The questioner is unsure of how to find the sum, and after initially misreading the solution, realizes that it is a geometric series in disguise. This explains why Wolfram Alpha gives the answer of 5/6.
APolaris
Question says: [itex]\sum(cos(n*pi)/5^n)[/itex] from 0 to infinity.
Proved that it converges: ratio test goes to abs(cos(pi*(n+1))/5cos(pi*n)) with some basic algebra. As n goes to infinity, this approaches -1/5 (absolute value giving 1/5) since cos(pi*(n+1))/cos(pi*n) is always -1, excepting the asymptotes.
Question wants to find sum. Wolfram claims sum is 5/6 and won't elaborate. How?
Edit: Nevermind, misread what you wrote. My bad.
The ratio test, I believe, is to use the limit as n goes to infinity of a(n+1) / a(n). So for detail:
cos (pi*(n+1))/5^(n+1) * 5^(n)/cos(pi*n).
I believe 5^n reduces with 5^(n+1) in the denominator, leaving 5 in the denominator, does it not?
Write out the first few terms of your series. You have a geometric series in disguise. That's how WA is summing it.
Thank you.
1. How do you calculate the sum of an infinite series?
The sum of an infinite series can be calculated using a formula or method specific to the type of series. For example, for geometric series, the sum can be found using the formula a/(1-r), where a is the first term and r is the common ratio. For the series mentioned, the sum can be found using the formula a/(1-r), where a = cos(0)/5^0 = 1 and r = cos(pi)/5 = -1/5. Therefore, the sum is 1/(1-(-1/5)) = 5/4.
2. What is the significance of the value of n in the given series?
The value of n in the given series represents the index or position of each term in the series. As n increases, the terms in the series will become smaller and approach 0, causing the overall sum to approach a specific value. In this case, the value of n also determines the value of the cosine function, as cos(n*pi) follows a repeating pattern with increasing values of n.
3. Can the sum of an infinite series be negative?
Yes, the sum of an infinite series can be negative, positive, or zero. It depends on the values of the terms in the series and the formula used to calculate the sum. In the given series, the sum is positive because the terms alternate between positive and negative values, resulting in a net positive value.
4. How does the value of the common ratio affect the sum of a geometric series?
The value of the common ratio in a geometric series has a significant impact on the sum of the series. If the common ratio is between -1 and 1, the series will converge to a specific value. If the common ratio is greater than 1, the series will diverge and have no finite sum. If the common ratio is less than -1, the series will alternate between positive and negative values, resulting in a sum that oscillates and does not converge.
5. Is it possible to find the exact sum of an infinite series?
In some cases, it is possible to find the exact sum of an infinite series using a specific formula or method. However, there are many types of infinite series that do not have a closed form solution and require numerical methods or approximations to find the sum. In the given series, the sum can be found using the formula for a geometric series and is therefore an exact value.
19K
