Infinite solubility of gases under extreme pressure
In summary, infinite solubility of gases under extreme pressure is the ability of gases to dissolve in a liquid to an unlimited extent when the pressure is increased to extreme levels. This is due to the direct proportionality between pressure and gas solubility. The practical significance of this phenomenon lies in its applications in various industries. However, there are limitations to this concept, such as changes in liquid properties and the possibility of certain gases not exhibiting infinite solubility. The main difference between infinite solubility and regular solubility is the pressure at which they occur, with infinite solubility occurring only at extremely high pressures and allowing for a higher amount of gas to be dissolved.
Syed F. Karim
At what depth (roughly speaking) will gaseous oxygen dissolve (because of the surrounding pressure) into the water? Again, not asking for a precise figure. Thanks
Oxygen will dissolve into water right at the surface.
- Warren
1. What is infinite solubility of gases under extreme pressure?
Infinite solubility of gases under extreme pressure refers to the phenomenon where gases can dissolve in a liquid to an unlimited extent when the pressure is increased to extreme levels. This means that the gas molecules are able to enter and dissolve in the liquid at a much higher rate compared to normal conditions.
2. How does pressure affect the solubility of gases?
The solubility of gases in a liquid is directly proportional to the pressure applied on the system. This means that as the pressure increases, the solubility of gases also increases. This is because the higher pressure causes the gas molecules to be compressed and enter the liquid at a faster rate, leading to higher solubility.
3. What is the significance of infinite solubility of gases under extreme pressure?
The infinite solubility of gases under extreme pressure has various practical applications in industries such as oil and gas, chemical manufacturing, and pharmaceuticals. It allows for the extraction of gases from liquids and the production of supersaturated solutions, which are used in various processes and products.
4. Are there any limitations to infinite solubility of gases under extreme pressure?
While the concept of infinite solubility may seem to suggest that gases can dissolve in a liquid to an unlimited extent, there are limitations to this phenomenon. Extreme pressures can lead to changes in the properties of liquids, such as their density and viscosity, which can affect the solubility of gases. Additionally, certain gases may not exhibit infinite solubility even under extreme pressure.
5. How is infinite solubility of gases under extreme pressure different from regular solubility?
The main difference between infinite solubility and regular solubility is the pressure at which the two occur. While regular solubility occurs at normal atmospheric pressure, infinite solubility only occurs at extremely high pressures. Additionally, infinite solubility allows for a much higher amount of gas to be dissolved in a liquid compared to regular solubility.
  • Mechanics
  • Mechanics
13K
  • Biology and Chemistry Homework Help
  • General Engineering
  • Mechanical Engineering
