Infinite square well transitions
  • Thread starter jbay9009
jbay9009
A particle, mass m propagates freely in a box, length L. The energy states are:
ϕ_n(x) = (2/L)^(1/2)sin(n∏x/L)
and energies E_n = n^2∏^2/(2mL^2)
at time t=0 the system is in state ϕ_1 and the perturbation V=kx is applied (k constant) and turned off at t=T.
1) Calculate the transition amplitude to the state ϕ_2 to 1st order in perturbation theory
2)Calculate the transition probability, p_21.
3)Calculate the maximum value of p_21.
Transition amplitude, T_fi = -i ∫ ϕ*_f V ϕ_i d^4x
= -i ∫(-T/2 to T/2)∫(-T/2 to T/2)∫ [ϕ_f exp(-iE_f t)]* V [ϕ_i exp(-iE_i t)] dx dt
where V = V_fi = ∫
1) T_12 = -i ∫ ϕ*_f V ϕ_i d^4x
= -i ∫(-T/2 to T/2)∫ [ϕ_2 exp(-iE_2 t)]* V(x) [ϕ_1 exp(-iE_1 t)] dx dt
= -i ∫ (2/L) sin(2∏x/L) kx sin(∏x/L) dx ∫(-T/2 to T/2) [ϕ_i expi(E_f-E_i)t] dt
using E_f-E_i = E_2-E_1 = 3∏^2/(2mL^2)
= 16ikL/(9∏^2) [exp(i 3∏^2/(2mL^2))-exp(-i 3∏^2/(2mL^2))] (2mL^2)/(3∏^2)) |(-T/2 to T/2)
=64ikmL^3/(27x^4) sin (T 3∏^2/(2mL^2) )
and so the transition probability, p= |T_21|^2 = |64ikmL^3/(27x^4)|^2 sin^2 (T 3∏^2/(2mL^2) )
and so p= |T_21|^2 has maximum values when T = integer 2kmL^2/(3∏)
Does this seem like the correct way of doing this problem / a reasonable result? It feels like I have done it the wrong way but I can't think of how else to do it.
Thanks for any help
Answers and Replies
TSny
3,837
It appears to me that your method is correct. You decided to integrate over time between -T/2 and T/2 rather than 0 to T. I think that's OK since your potential function V is time independent, but it seems more natural to me to integrate from 0 to T since the perturbation is switched on at t = 0 and switched off at t = T.
Note that the probability cannot depend on the variable x, so this expression is incorrect (maybe just a typographical error). Also, if I'm not mistaken, I believe your argument of the sin function is off by a factor of 2.
Suggested for: Infinite square well transitions
