Infinite Square Well
  • Thread starter jaydnul
The wording of the question is throwing me off. It is a standard inf. pot. well problem and we are given the initial position of the particle to be in the left fourth of the box,
[itex]\Psi(x,0)=\sqrt{\frac{4}{a}}[/itex]
We are asked to a) write the expansion of the wave function in terms of energy eigenfunctions, b) explicitly compute the expansion coefficients, and c) give an expression for psi at later times.
[itex]E_n=\frac{n^2\pi^2\hbar^2}{2ma^2}[/itex]
[/B]
I got b) and c) (I can show my work if necessary)
b) [itex]c_n=\frac{4\sqrt{2}}{n\pi}[/itex] for n= odd
[itex]c_n=0[/itex] for n= even
c) some long expression that I don't want to latex f I don't have to, but will if needed (on my phone :) )
But for a), I would think E_n would be the same as any inf. pot. well problem, wouldn't it? So
[itex]E_n=\frac{n^2\pi^2\hbar^2}{2ma^2}[/itex]. Is this right?
Answers and Replies
Like usual, writing it out on PF helped me solve the problem. At t=0, [itex]k_n=\frac{4n\pi}{a}[/itex] which allows the calculation of energy.
Thanks anyways
What did you get for part a) ?? I am stuck and I am confused what the first step should be. Thanks.
Simon Bridge
17,857
1,655
Welcome to PF;
You will need to work out what ##\psi## (the initial position wavefunction) is from the description - show us what you got along with your reasoning.
For part (a) start with: $$\psi = \sum_n c_n\psi_n : \hat H\psi_n=E_n\psi_n$$ ... you should have notes for what each ##\psi_n## will be so you can look them up.
Related Threads on Infinite Square Well
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
