Homework Help: Infinite Square Well
  1. Oct 25, 2016 #1
    ISW walls at 0 and L, wavefunction ψ(x) = { A for x<L/2; -A for x>L/2. Find the lowest possible energy and the probability to measure it?
    2. Relevant equations
    Schrodinger equation
    ψ(x)=(√2/L)*(sin(nπx/L)
    cn=√(2/a)∫sin(nπx/L)dx {0<x<a}
    En=n2π2ħ2/2ma2
    3. The attempt at a solution
    First I normalized and found A= 1/√L
    Lowest energy = E12ħ2/2mL2
    But I'm going wrong on finding the probability.
    P1=|c1|2
    When finding cn, I split the integral into two parts, one for ψ(x) = A for x<L/2 and one for ψ(x) = -A for x>L/2 and I get as a result:
    (-2/(√L)nπ)(2cos(nπ/2-cosnπ-1) which equals 0 for odd n's and 8/(√L)nπ for even ones. Problem arises when I put that into my probability I'm left with my probability dependent on L - how is it possible that the probability of a particle having a certain energy be dependent on the size of our made up box? I've checked the integral over a thousand times and can't find a mistake. Help?
  3. Oct 25, 2016 #2
    DrClaude
    Staff: Mentor
    Is this equation correct?
    Not sure what that represents.
    Are these two statements compatible?
  4. Oct 25, 2016 #3
    the probability of a particle confined in a box of infinite depth is a confinement and its energy goes higher as the width is lower.
    the position probability is never a constant inside a box .pl. check your calculation and the limits . it may be zero at certain points.and maximum at other points.
    one should see a text book for plot of probability for different states .
  5. Oct 25, 2016 #4
    TSny
    2017 Award
    All of your work looks good, except I don't agree with your numerical factor out front in your result for the integration. As you say, L should not appear. I also get √2 in the numerator instead of 2. So, check your integration again (makes a thousand and 1 times).
    When writing fractions with the symbol /, make sure you put the entire denominator in parentheses to agree with "order of operations".
  6. Oct 25, 2016 #5
    TSny
    2017 Award
    That's true if the particle is in one of the energy eigenstates. But here, it is assumed that the particle is in the state given (which would be a superposition of energy eigenstates). The boundary conditions require that the wavefunction goes to zero at the endpoints of the well. So, I guess you need to assume the wavefunction goes from ±A to zero over a negligible interval near the endpoints.
  7. Oct 28, 2016 #6
    Thanks everyone for your help. I realized my entire problem came from me not copying down the coefficient equation correctly when I went to solve it.
Have something to add?
Draft saved Draft deleted
