Infinite Sum
  • Thread starter cepheid
cepheid
Staff Emeritus
38
I'm trying to figure out how to do this sum and not sure where to start:
[tex] \sum_{n = -\infty}^{-1} \left(\frac{1}{2}e^{-j \omega} \right)^n [/tex]
I tried rewriting it like this:
[tex] \sum_{m = 1}^{\infty} (2e^{j \omega})^m [/tex]
m = -n
but I'm not sure if that helps.
Answers and Replies
0rthodontist
What are j and omega? Unless I'm missing something you have an infinite power series with ratio r = 2e^(j * omega) whose sum can be found by the formula r/(1-r).
d_leet
1,077
That will work provided that (j*omega) < ln(1/2) because in order for an infinite geometric series to converge the common ratio must be less than 1.
0rthodontist
True.
whitespace
cepheid
Staff Emeritus
38
Tsk tsk. You guys don't instantly recognize the combination jω?
[tex] j = \sqrt{-1} [/tex]
I know I know. Those crazy electrical engineers...and omega is of course the angular frequency. What you are looking at is the calculation of the Fourier transform of a discrete time signal x[n], n in the set of integers.
Anyway, you must be wondering, if that's a complex exponential, then how could the series possibly converge? Well it's a moot point, because I made a mistake. Originally I had:
[tex] X(e^{j \omega}) = \sum_{n=-\infty}^{\infty}x[n]e^{-j \omega n} = \sum_{n=-\infty}^{-1}\left(\frac{1}{2}\right)^{-n}e^{-j \omega n} [/tex]
Which I should have expressed like so:
[tex] \sum_{n=-\infty}^{-1}\left[\left(\frac{1}{2}\right)^{-1}e^{-j \omega }\right]^n [/tex]
which is decidedly different from what I started out with in my first post. It becomes (setting m = -n):
[tex] \sum_{m=1}^{\infty}\left(\frac{1}{2}e^{j \omega }\right)^m = \frac{\frac{1}{2}e^{j \omega }}{1 - \frac{1}{2}e^{j \omega }}[/tex]
Correct?
Suggested for: Infinite Sum
  • Last Post
  • Last Post
  • Last Post
