Infinite Summation: Solving xln(a)^n/n!
In summary, the homework statement asks us to investigate the sum of an infinite sequence, and suggests that the sum may converge as n becomes arbitrarily large. We are expected to use a calculator or graphing software to deduce this, but we are not given any formal methods for doing so. We are also expected to understand the proofs for this convergence, but we were not exposed to them in this class.
theJorge551
68
"Aim: In this task, you will investigate the sum of infinite sequences tn, where
tn = [tex]{\frac{(x\ln{a})^n}{n!}}[/tex], and t0=1
Consider the sequence when x=1 and a=2.
Using technology, plot the relation between Sn (the sum of t0+...+tn) and the first n terms of the sequence for [tex]{0}\leq{n}\leq{10}[/tex].
What does this suggest about Sn as n approaches [tex]\infty[/tex]?"
We were given this assignment (which originally is much lengthier than this, but this is the core idea of it) with the prospect of using a calculator and/or graphing software to deduce that the value of the sum of this sequence converges as n becomes arbitrarily large. We have never been exposed to infinite sums (or even calculating the value of non-infinite sums) and are expected to do this completely dry, not using any formal analysis of the sum. I'm suspicious that this sum,
[tex]\sum\limits_{n=0}^{\infty}{\frac{(x\ln{a})^n}{n!}}[/tex]
has an analytic solution, and I'd love to find out what it is. I'm also taking AP Calculus BC as a parallel to this class, but we haven't come close to infinite sums yet. I've done a lot of integration and significantly more differential calculus independently. I was wondering, what direction should I take if I wanted to include an analytical solution for this convergence (not just plugging in values into a calculator and seeing where it leads, as my school wants me to)? Thanks, any help appreciated.
let [tex]y=x\ln a=\ln (a^{x})[/tex], then you're talking about the series:
[tex]
\sum_{n=0}^{\infty}\frac{y^{n}}{n!}=e^{y}
[/tex]
You are correct, there is an analytic solution: the sum of the series is [tex]ae^x[/tex].
So if x=1 and a=2, then the series simply converges to 2.
However, the proof of this fact entails Taylor series and other stuff. And if you have never seen series before, then I think that the proof is out of your grasp. I guess that the purpose of the assignment was that an infinite sum can give a finite answer and that this answer can be approximated...
Maybe I should have been more clear in my original post; I've seen sequences before but I've never done calculations that reduce the value of the sum to a concise little formula. I've seen the proofs for this being done but I've never learned any hard and fast methods of creating one of these short formulas, and I'd really like to. I'll still have to do the tedious plotting, but doing things ad-hoc like that drives me absolutely insane! My math teacher will surely get sick of me peppering him with questions.
So you have seen sequences before, that's good. Have you seen the theorem of Taylor somewhere? Or Taylor series? Because that is what will help you are.
In general, giving an analytic answer to an infinite sum is impossible... It can only be done for very specific infinite sums. For example, nobody really knows what
[tex]\sum_{n=1}^{+\infty}{\frac{1}{n^3}}[/tex]
equals. And this is really an innocent looking sum. However, the sum that your teacher gave you is a very famous one. And you will certainly see it again. But you'll need some more calculus to show that the sum does in fact equal 2...
If you read my post you would have realized it was a^{x} rather than ae^{x}
Yes, of course, stupid me :tongue:
Thanks guys! I'm teaching myself Taylor polynomials and series now. I hope to have grasped the reasoning behind this summation before the end of the two-week session we have to work on this project, so I can put the actual analysis at the end of my report. I find it really pointless to give us such a task without having any sort of challenge; plugging numbers into a calculator for half a month doesn't sound like anything of that nature.
Edit: I understand it now, and can't wait to get to Taylor series in my Calculus class so I can formally learn it! Great stuff. Now, to destroy this terrible assignment..
What is infinite summation?
Infinite summation is a mathematical concept that involves calculating the sum of an infinite number of terms. It is denoted by the symbol ∑ and is commonly used in calculus and other branches of mathematics.
What is xln(a)^n/n! in infinite summation?
xln(a)^n/n! is a specific type of infinite summation where the terms in the series follow a specific pattern. In this case, the value of x is raised to the power of n and then multiplied by the natural logarithm of a, before being divided by n factorial (n!). This series can be simplified and solved using various mathematical techniques.
What is the significance of solving xln(a)^n/n! in infinite summation?
The solution to xln(a)^n/n! in infinite summation can have various applications in fields such as physics, engineering, and statistics. It can be used to model and solve real-world problems that involve an infinite number of terms, and can also provide insights into the behavior of certain mathematical functions.
What are some techniques for solving xln(a)^n/n! in infinite summation?
There are several techniques that can be used to solve xln(a)^n/n! in infinite summation, including the ratio test, root test, and comparison test. Other methods such as integration and differentiation can also be applied depending on the specific form of the series. It is important to carefully analyze the series and select the appropriate technique for solving it.
Are there any special cases or exceptions when solving xln(a)^n/n! in infinite summation?
Yes, there are certain cases where the series may not converge or the solution may not be valid. For example, if the value of x is greater than 1, the series will diverge. Additionally, the value of a must be greater than 0 for the series to converge. It is important to carefully check for these special cases and ensure that the solution is valid before using it.
