Exploring the Infinitude of the Universe
  • Thread starter Moni
  • Tags
    Universe
In summary, the conversation discusses the concept of infinity and whether or not the universe is infinite. There is no definitive answer as it is a topic of speculation and belief. Some argue that it is impossible to truly comprehend infinity as it has no boundaries or edges. Others suggest that through logic and reasoning, we can understand it to some extent. The concept of infinity is often used in contexts where quantities have no upper bound, such as the size of sets or distances in the universe.
  • #106
Originally posted by Hurkyl
Some more interesting examples of distinguishing illusions would be nice. What about optical "illusions" and magic tricks of various sorts? What about the "illusion" of stillness?
Perceptions are specialized and easily tricked.
[quite]On another topic, what are sufficient ways to verify something is real besides sensing them?
Everything is real. Non-real things do not exist, by definition. Sensation is the root of all mental contact with reality. From there we can build artificial senses (atomic force microscopes etc.) and logic systems to understand aspects of the causality of the system.
In any case, from your response, it seems that the meaning "motion of matter" does indeed have nothing to do with the meaning of "cause and effect" and you are trying to explain why there is an "illusion" of cause and effect. Correct?
In a sense that is correct, but only in the sense of the difference in the root-level causality and the macro-scale manifestation of causality. When I say "matter in motion" there is a tendency to imagine a kinetic-atomic model of atoms (or objects) bouncing around in a void. This is not what I mean. I am talking about matter as a compressible fluid-dynamic frictionless continuum--in turbulent motion, compressing, rotating etc.
Are there two types of matter now? Atomic and ...fluid-dynamic...?
Root-level matter is the continuum mentioned above and atomic matter is formed by a circle of cause and effect--venturi-stabilized rotational compression->increasing torque->increasing venturi effect etc. until a pressurized equilibrium is reached in which the structure is an intensely steep density gradient of raw matter-- an atom. There are harmonic wave-equilibration processes which quantize this gradient into a series of shells in the Schrodinger electron density pattern (seen in Bodes Law as well).
So there is some concept of place. Are places real? There is some concept of change; does that imply a concept of time, and is time real?
Matter is extended and this extension is real. "places" are real therefore as well.
Is pressure matter?
Yes, in raw matter they are unequilibrated density deviations...either positive or negative (also known as charge).
So everything real is made out of matter, and everything made out of matter is real? This brings us no closer to being able to identify just what is real, but it's good to have performed this identification.
Yes. Everything that exists is real.
Of everything that exists, that which looks like something else, is an illusion.
  • #107
Why there has to be objective reality
https://www.physicsforums.com/showthread.php?s=&threadid=3703"
Which reasons about the question "Why is there something instead of nothing" and which concludes that there must have been something apart, outside and independend of consciousness, that has existed always.
  • #108
Recall that I was talking about recognizing illusions; how do we discover if our perceptions have been tricked?
Everything is real.
If A is an illusion that looks like B, it seems clear by your terminology that the illusion of B is real... but is B real?
Is curved space real?
Is there anything that satisfies the proposition "X is not real"?
So theory and experiment may, indeed, suffice as replacements for direct sensation. Allow me to set this idea on the back burner a bit before we go into depth how this may be done.
But allow me ask one question; if it takes much more than a "yes" or "no" answer, we can defer it until later... is it ever acceptable to trust these artifical senses and logic systems when they contradict our senses?
For example, in the famous optical illusion of circles surrounded by circles, is it acceptable to trust the ruler (and implicitly the theory that rulers are good measuring devices) when it says they are the same size, despite my vision telling me otherwise?
I'm avoiding ascribing any physical idea to "matter in motion" at this time, for the purposes of this discussion. I'm talking neither about bouncing balls nor flowing fluids; I'm trying to develop an acceptable framework of discovery which we can use to make this discovery. Might "time evolution" be an acceptable synonym for "cause and effect"?
Root-level matter is the continuum mentioned above and atomic matter is formed by ...
To avoid fixing the discussion to anyone theory (and to better follow the flow of the discussion so far as to determining what is an acceptable way to understand the universe), would it suffice it to say that you are using the term "matter" both for "root-level matter" (which is, in some sense, fundamental) and for observable patterns of that root-level matter?
Is there any way we could deduce this conclusion from observation, or must we accept it as an axiom for this discussion? And would the term "point" be an acceptable synonym for "place", in the sense we can say that the universe is "made" of points, and matter extends through these points? By "made" of points, that just means that all extensions of matter can be described by the points through which it extends.
This is in accordance with my previous comment on the term "matter" correct; pressure is not fundamental matter, but an observable pattern in root-level matter. Allow us to hold off on more precise meanings of pressure.
  • #109
If 'X' were defined as a consciouss actor outside of space time and matter, I would say then that 'X is not real'.
  • #110
Excellent definition. "Outside of space time and matter" could be simplified to "outside causality", however.
  • #111
hmmm... let me take a crack at it.
you have to develop tricks of your own to trick the tricks!
everything is real
Yes "curved space" is a real map of a real field whose essense is really unknown by modern physics.
It depends on your definition of "real". The definitions of these terms are not very well specified so we unconsciously blurr the distinctions.
Yes, but mathematics is not a substitute for causality.
Artificial senses ARE senses. If the senses contradict each other then one must understand the nature of this contradiction before one can trust the senses.
Logic is beyond sensation. It is an artificial, symbolic causality. If it contradicts our experiential understanding of causality, then that is another story and the answer is emphatically "NO". If we abandon causality then there is no way to maintain contact with reality. Our constructions will wander off into a fantasy land with no restrictions as to a deeper physical order.
Of course. The real relations are simply mis-interpreted by the specialized mechanisms of the brain.
A more abstract one so it must be used with caution and always kept in check with the deeper level.
Everything is made out of the same matter. It is important to make a distinction here however. Spinoza uses the terms "Substance" and "modes". Substance is the root level continuous stuff and modes are the finite patterns made out of that substance. These terms will suffice for this discussion.
I feel it is not only quite readily apparent, but it is absloutely logically necessary. Can you imagine any metaphysics without including extension?!
I would say that it is confusing to say that the universe is made of points because points are mental mathematical extensionless place-holders for places and the Universe clearly is not made out of extensionless place-holders.
Yes pressure and charge are modes not substances, of which there can be only one.
  • #112
Why the name change, subtillioN?
  • General Discussion
  • Beyond the Standard Models
