Inflationatory universe
  1. Feb 12, 2007 #1
    This problem concerns a simplified model of the history of a flat universe involving a period of inflation. The history is split into four periods:
    (a) [itex]0<t<t_3[/itex] radiation only
    (b) [itex]t_3<t<t_2[/itex] vacuum energy dominates, with an effective cosmological constant [itex]\Lambda = \frac{3}{4} t_3^2[/itex]
    (c) [itex]t_2<t<t_1[/itex] a period of radiation domination
    (d) [itex]t_1<t<t_0[/itex] matter domination
    Give simple analytical formulae for the expansion parameter [itex]a(t)[/itex] which are approximateley true in these four phases.
    2. The attempt at a solution
    In epoch (d) I guess the ordinary solution for radiation dominated universes holds:
    [tex] a(t)=a_0 \left( \frac{t}{t_0} \right) ^{2/3}[/tex]
    and in epoch (c) I guess for the matter solution
    [tex]a(t) = a_0 \left( \frac{t}{t_0} \right) ^{1/2}[/tex]
    but here I have used the present scale factor [itex]a_0[/itex] and present time [itex]t_0[/itex] in both cases. Is that really correct?
    For the epoch (b) I have used a de Sitter solution with a cosmological constant as
    [tex]a(t) = A exp \left[ \left( \frac{1}{3} \Lambda \right)^{1/2} ct \right][/tex]
    but I don't know if this is true.
    For the first epoch I have no clue. Should I use the ordinary radiation dominated solution or should I look at more Planck scaled solutions?
