Do all objects absorb different wavelengths of light and convert it into heat?
In summary: lightbulbs are cooled by the heat they generate), while other light waves are scattered in all directions and don't do anything.
dionysis
I know there is an equation somewhere that tells the wavelength of light given off by an object at a certain heat. So does this work backwards as well? do you get maximum heating of an object if you heat it with that wavelength light? if so, then you could vary the wavelength as the heat in the object increases to continue maximum heating?
1 more:
is it just a coincidence that infrared electromagnetic waves are considered "heat" waves, the coicidence being that most objects at normal heat give off infrared wavelengths?
do any objects give off things like radio waves when excited or cooled?
Science news on Phys.org
I think you're referring to blackbody radiation, whereby a body that has temperature will radiate heat energy, and the frequency/wavelength of that radiation is only dependent on the body's absolute temperature.
I don't think it works the other way round. The amount of radiation absorbed by a body depends on the type of surface, which has no relation to the absolute temperature (that is to say, the type of surface doesn't vary with temperature).
In general, heat in the form of radiation is infrared waves, so I don't think it's coincidence... they are the same thing.
For a perfect "black body" the radiation and absorption work exactly the same way and depend on the temperature of both the black body and the incident radiation.
"In general, heat in the form of radiation is infrared waves"
yea that's what everybody tells me, but i'd like alittle better explanation insated of 'this is the way it is, go figure'
thanks for any replys so far tho. =]
Dont radiating sources give off waves from all of the electromagnetic spectrum??
Yes, and the equation works for the wavelength of maximum emission.
Yes, but in the energy levels generally associated with sensible heat, its centered around ir.
If you're talking about a true blackbody, then all incident radiation is absorbed and converted to heat. There is no most efficient wavelength. Of course, there are no true blackbodies, just approximations.
To heat true materials, you do best by applying radiation at the electron transition levels. Which transitions to use is temperature dependent, as some levels become depopulated at different temperatures.
Generating light in narrow bands is inefficient though. This is why we don't cook things with lasers. The efficiency you gain by applying the correct wavelengths is not enough to make up for the efficiency you lose generating the light.
Njorl
I think that infrared just defines a temperature range of heat and is not heat in an exclusive way. When temperature rises to a point that green and yellow light are emitted(as in the solar light spectrum) heat is being produced by almost just as much from these bands than from the infrared band. This is my understanding. In general, I think the confusion arises for many people because they don't understand the difference between heat and radiation. Electroradiation of all kinds can be transformed into heat.
Hope this will help: Radio-waves can be transformed into heat, but it is usually a low form of energy(frequencies are low) so low emissions of heat are associated with these waves and can't be felt unless you ramp up the intensities. Micro-waves generate heat: as they are absorbed, the absorbing substance uses some of the energy in the form of kinetic movement of its particles and the rest gets transformed into heat(which we take advantage of to "heat our food"). Infra-red also get absorbed into things, transforming some of it(in varying degrees according to the substance) into heat. Most of the heat we feel in normal ranges is associated with the conversion of infrared energy waves into heat energy. But even optical light being absorbed gets to varying degrees transformed into heat. Some light gets absorbed and used to do work(ie photosynthesis) and other parts of that light can get converted to heat. Infrared is not in itself heat. Electromagnetic radiation is a method for transferring energy; heat is another method. Electromagnetic energy can and often is transformed into heat energy.
1. What are infrared waves?
Infrared waves are a type of electromagnetic radiation with longer wavelengths than visible light. They are invisible to the human eye but can be detected as heat.
2. How is heat related to infrared waves?
Infrared waves are often referred to as "heat waves" because they carry thermal energy. When these waves come into contact with an object, they cause the particles in that object to vibrate, producing heat.
3. How do infrared waves affect temperature?
Infrared waves can increase the temperature of an object by transferring thermal energy to it. This is why objects exposed to sunlight feel warmer - they are absorbing infrared waves from the sun's rays.
4. What are the practical applications of infrared waves?
Infrared waves have a wide range of applications, including thermal imaging, heating and cooking, communication, and medical imaging. They are also used in industrial processes, such as drying and curing materials.
5. Can infrared waves be harmful?
Infrared waves are generally not harmful as they have lower energy levels compared to other forms of radiation like X-rays and gamma rays. However, prolonged exposure to high levels of infrared radiation can cause damage to the eyes and skin.
  • Thermodynamics
9K
16K
  • Thermodynamics
  • Quantum Physics
  • Other Physics Topics
16K
