swatmedic05
- 42
A particle has an acceleration of 6.09m/s for 0.350s . At the end of this time the particle's velocity is 9.41
How do I find the inital velocity
swatmedic05 said:A particle has an acceleration of 6.09m/s for 0.350s . At the end of this time the particle's velocity is 9.41
swatmedic05 said:Every body remains in a state of rest or uniform motion (constant velocity) unless it is acted upon by an external unbalanced force
But, you are wrong.So would the answer be zero?
Initial velocity, also known as initial speed, is the velocity of an object at the beginning of its motion. It is the rate at which an object changes its position in a certain direction.
Initial velocity can be calculated by dividing the change in position by the change in time. It can also be calculated by using the equation v = u + at, where v is the final velocity, u is the initial velocity, a is the acceleration, and t is the time.
Initial velocity is the velocity of an object at the beginning of its motion, while final velocity is the velocity of an object at the end of its motion. Final velocity takes into account any changes in velocity during the motion, while initial velocity does not.
The initial velocity of an object can be affected by factors such as the force applied, the mass of the object, and any external forces acting on the object. The medium in which the object is moving, such as air resistance, can also affect the initial velocity.
Initial velocity is important in physics because it is the starting point for analyzing an object's motion. It helps determine the object's acceleration, displacement, and final velocity. It is also crucial in understanding the laws of motion and how forces act on objects.
