Find Time in Air for Ball Launched Upward with 18 m/s
In summary, the equation that should be used to find the time the ball was in the air is the Kinematic Equations of Motion for constant acceleration, since the acceleration due to gravity is constant on the Earth's surface.
iac0b
A ball is launched directly upward from ground level with an initial speed of 18 m/s. (Air resistance is negligible.)
What equation would I use to find the time the ball was in the air?
Welcome to the PF.
Thread moved to Homework Help / Intro Physics.
You would use the Kinematic Equations of Motion for constant acceleration (since the acceleration due to gravity is constant on the Earth's surface). See half-way down this wikipedia page:
http://en.wikipedia.org/wiki/Kinematic_equations#Equations_of_uniformly_accelerated_motion
1. What is the formula for finding the time in air for a ball launched upward with a velocity of 18 m/s?
The formula for finding the time in air for a ball launched upward is t = (2v/g), where t is the time in seconds, v is the initial velocity in meters per second, and g is the acceleration due to gravity (9.8 m/s^2).
2. How do you calculate the time in air for a ball with an initial velocity of 18 m/s?
To calculate the time in air for a ball launched upward with an initial velocity of 18 m/s, you can plug the values into the formula t = (2v/g). This will give you the time in seconds that the ball is in the air before it reaches its maximum height and starts to fall back down.
3. Can you use the same formula to find the time in air for a ball launched downward?
No, the formula t = (2v/g) is specifically for a ball launched upward. For a ball launched downward, the formula would be t = (v/g), where t is the time in seconds, v is the initial velocity in meters per second, and g is the acceleration due to gravity.
4. How does air resistance affect the time in air for a ball launched upward?
Air resistance can affect the time in air for a ball launched upward by slowing down the ball's velocity as it travels through the air. This means that it will take longer for the ball to reach its maximum height and fall back down, resulting in a longer time in air.
5. What other factors can impact the time in air for a ball launched upward?
Other factors that can impact the time in air for a ball launched upward include the angle at which the ball is launched, the mass of the ball, and the elevation of the launch point. These factors can affect the initial velocity and trajectory of the ball, which in turn can affect the time it takes for the ball to reach its maximum height and fall back down.
