Homework Help: Initial Value Problem
  1. Nov 3, 2005 #1
    The problem:
    The acceleration of a particle moving back and forth on a line is a = (d^2)s/d(t^2) = (pi)^2 cos(pi)(t) m/sec^2 for all t. If s = 0 and v = 8 m/sec when t = 0, find s when t = 1 sec.
    My work:
    ds/dt = (pi)^2 sin(pi)(1) + C
    ds/dt = (pi)^2(0) + C
    0 = C
    Then..
    ds/dt = (pi)^2 sin(pi)(t)
    s = -(pi)^2 cos (pi) (8)
    0 = -(pi)^2(1) + C
    (pi)^2 = C
    So my answer turned out to be (pi)^2 meters. I'm not so sure that that's the correct answer though.
    Any help is appreciated.
  3. Nov 3, 2005 #2
    well, oook.
    First of all, you start with acceleration as a function of time yes? [tex] a(t) = \pi^2 cos(\pi t)[/tex] when you integrate [tex]\frac{d^2 s}{dt^2}=\pi^2 cos(\pi t)[/tex] this is an equation for velocity as a function of time [tex] v(t)= \frac {ds}{dt}[/tex] right?
    so, first when you integrate, [tex]cos(\pi t) dt[/tex] its the opposite of the chain rule, so you have to divide by the coefficient of t, in this case, pi. so you get,
    [tex]v(t) = \frac{ds}{dt}=\pi sin(\pi t) +C[/tex]
    then to solve for C you plug in the given values for v and t and solve.
    Then because you want s(t), you integrate once more. and you solve for C again with the given initial values of s and t. then you plug in t=1 into your final equation and solve for s.
  4. Nov 3, 2005 #3
    Hurkyl
    Staff Emeritus
    A quick notational fix for the original poster:
    The notation:
    [tex]\frac{d^2 s}{dt^2}[/tex]
    means
    [tex]\frac{d^2 s}{(dt)^2}[/tex]
    or equivalently,
    [tex]\left( \frac{d}{dt} \right)^2 s[/tex]
  5. Nov 3, 2005 #4
    oh man, you scared me when i saw your post after mine... i thought i'd done something wrong! whew.
  6. Nov 3, 2005 #5
    Hurkyl
    Staff Emeritus
    Nah, your work looks fine! :smile: The only thing I might consider complaining about is that you did virtually all the work for the OP.
  7. Nov 3, 2005 #6
    Ah, I think I've got it now. I just hope I won't confuse this with anything else on my test tomorrow. :P
    Thanks!
  8. Nov 4, 2005 #7
    HallsofIvy
    Sedm: another notational point. Many of us might be inclined to read
    cos(pi)(t) as {cos(pi)} t, in which case, your original calculation would be correct: the derivative of that would be {cos(pi)} but NOT the anti-derivative! Clearly you meant cos(pi t). The anti-derivative of that is
    (1/pi) sin(pi t). I don't know why had "1" in place of t.
    Hurkyl: ?? What??
    [tex]\frac{d^2 s}{dt^2}[/tex] is the second derivative. It definitely is not
    (I'm not even sure what that could mean!)
    Yes, you could write that as
    but you had better make it clear that that is NOT
    [tex]\left(\frac{ds}{dt}\right)^2[/tex]!
Loading...
Similar Threads for Initial Value Problem Date
Initial value problem question Feb 17, 2018
Solution to complex valued ODE Feb 15, 2017
Differential Equation Initial Value Problem Feb 14, 2017
Initial Value Problem Jan 22, 2017
Initial Value Problem for (DE) Jan 17, 2017
