Exploring Initial Conditions for ODE Solution
In summary, the conversation discusses choosing initial conditions for the general solution of an ODE and why x(0) and v(0) are chosen instead of x(0) and a(0). The question is raised about why acceleration cannot be specified as an initial condition, and the answer is given that it is determined by the spring's properties once x(0) is specified. The conversation also mentions finding information on oscillations in Feynman's lectures.
littleHilbert
56
Hi, World! Nice place here! My first post in this forum. :smile:
I've got a short question for a start.
If we wish to evaluate the constants for the general solution
[itex]x(t)=C_1e^{-{\lambda_1}t}+C_2e^{-{\lambda_2}t}[/itex]
of this ODE:
[itex]\ddot{x}+2{\gamma}\dot{x}+{{{\omega}_0}^2}x=0[/itex]
we can choose the initial conditions: [itex]x(0)=x_0,\dot{x}(0)=v_0[/itex]
I cannot see at a glance why we can't choose an initial condition of acceleration and try to calculate the constants using this value. Why do we choose [itex]x_0,v_0[/itex] and not for example [itex]x_0,a_0[/itex] with [itex]a_0={{\lambda_1}^2}C_1+{{\lambda_2}^2}C_2[/itex]?
Hey, Guys...why silence?
Did I ask nonsense? :uhh:
I don't think it's nonsense. :grumpy:
In the meantime I came across some info on oscillations in Feynman's lectures.
It says we cannot specify acceleration with which the motion started because it is determined by the spring, once we specify [itex]x_0[/itex]. But isn't the velocity also dependent on the properties of the spring then?
Hello and welcome to the forum! It's great to see people exploring and asking questions about initial conditions for ODE solutions.
To answer your question, the choice of initial conditions for an ODE solution is not arbitrary. It is based on the structure of the equation and the physical interpretation of the variables. In this particular equation, x(t) represents the position of a particle at time t, and \dot{x}(t) represents its velocity. Therefore, it makes sense to choose initial conditions that correspond to the position and velocity of the particle at time t=0.
Choosing x_0 and v_0 as initial conditions allows us to uniquely determine the values of C_1 and C_2 in the general solution, and thus fully define the solution for all values of t. If we were to choose a_0 instead, it would not provide enough information to determine the values of C_1 and C_2, and the solution would not be fully defined.
Additionally, the equation \ddot{x}+2{\gamma}\dot{x}+{{{\omega}_0}^2}x=0 is a second-order differential equation, meaning it involves the second derivative of x. This means that the initial conditions must also be specified for the first and second derivatives of x, which is why we choose x_0 and v_0 as initial conditions.
I hope this helps clarify the reasoning behind the choice of initial conditions for ODE solutions. Keep exploring and asking questions!
1. What are initial conditions in an ODE solution?
Initial conditions in an ODE (ordinary differential equation) solution refer to the values of the dependent variables at a specific starting point in time or space. They are necessary for solving the ODE and obtaining a unique solution.
2. Why is it important to explore initial conditions for ODE solutions?
Exploring initial conditions allows us to better understand how the system behaves over time and determine the impact of different starting points on the solution. It can also help identify critical points and determine stability of the system.
3. How do scientists determine the appropriate initial conditions for an ODE solution?
The appropriate initial conditions for an ODE solution are typically determined based on the physical or mathematical properties of the system being studied. They can also be estimated from experimental data or previous knowledge of the system.
4. Can the initial conditions for an ODE solution be changed?
Yes, the initial conditions for an ODE solution can be changed. However, altering the initial conditions can significantly impact the behavior of the system and may result in a completely different solution.
5. Are there any limitations to exploring initial conditions for ODE solutions?
One limitation is that exploring initial conditions can be time-consuming and may require a large amount of computational resources. Additionally, the results of the exploration may not be applicable to all situations and may only provide insight into a specific set of initial conditions.
  • Math POTW for University Students
