Initial velocity
What formula would I use to find the initial velocity?
An object is thrown vertically into the air and reaches a height of 30.0 m. Neglecting air friction, what was the object’s initial velocity?
I dont quite remember how to do this. Is it 30.0m / 9.81[m/s]^2?
Answers and Replies
rock.freak667
6,223
31
There are mainly three equations of motion
[tex]s= ut+\frac{1}{2}at^2[/tex]
[tex]v=u+at[/tex]
[tex]v^2=u^2+2as[/tex]
u= initial velocity
v= final velocity
s= displacement.
Which one has all of the information you need in it? (note: a is acceleration, which is just 'g' in your case)
Hello :)
I'm not given the time so I'm assuming its v^2=u^2+2as ?
rock.freak667
6,223
31
Hello :)
Yes, also since the maximum height is given you have the final velocity.
Thank you! :)
one more question, how would I find the initial velocity? Would it be 0? or 9.81[m/s]^2? dont remember that part either :\
rock.freak667
6,223
31
Thank you! :)
Remember m/s2 are the units for acceleration, so in your equation, your acceleration is -9.81.
At the maximum height, the object stops rising. So the final velocity is?
When you understand these two things, using the equation you told me it would be v2=u2+2as, you can can find 'u'.
the final velocity would be (30.0m) (-9.81)?
rock.freak667
6,223
31
no, remember the object's goes up, reaches the maximum height and then moves back down to Earth. So during this, the velocity goes from +ve to 'something' (at max) and then -ve as it moves back down to Earth. What is the 'something' ?
rock.freak667
6,223
31
displacement? :\
no no, I am trying to get you to understand what the final velocity is at the maximum height.
Say you throw something up in the air. It does not continuously move upwards, eventually it fall back down, for it to change direction, what must it instantaneously do?
For a similar analogy, say you are driving forwards, for you to move backwards, what should happen to your forward velocity before you start to move backwards?
It would decrease velocity? =)
rock.freak667
6,223
31
Right yes, as it moves up, it decrease velocity until it reaches what at the max height?
(Because for it to change direction, it needs to stop moving up and then start moving down)
rock.freak667
6,223
31
final velocity?
If at the maximum height the object instantaneously stops, the final velocity is?
rock.freak667
6,223
31
0? :)
Right! So v=0
v2=u2+2as
v=0
u2+2as = 0
(remember 'a' is negative)
Thanks! :)
So..
a=-9.81m/s
s=30.0m
v=0
u2??
How would I find the initial velocity now?
rock.freak667
6,223
31
Thanks! :)
So..
a=-9.81m/s
s=30.0m
v=0
u2??
30*-9.81?
u2-2as=0
rearrange for u2 and then take the square root of both sides.
Related Threads on Initial velocity
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
