• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Input/Output Impedance
  • Thread starter Duave
The Meaning Of An Active Bandpass Filter
1. Homework Statement
Calculate the node voltages V1 and V2. Assume that the 0 ohm resistor is an ammeter, and that the zero current element is a voltmeter.
https://scontent-b.xx.fbcdn.net/hphotos-ash3/t1/1898156_10151912573775919_1335607656_n.jpg
2. Homework Equations
KVL and KCL calculation format.
3. The Attempt at a Solution
Can you please tell me if my calculations are correct.
Node 1: V1/0ohm -V1/30ohm + 100V/10ohm = 4
-V1 + 300V = 120V
V1 = 180V
Node 2: V2 = (4A)(7.5ohm)
V2 = 180V
Thank You
NascentOxygen
Mentor
9,215
1,056
That's an interesting choice of title for your thread, Duave. http://physicsforums.bernhardtmediall.netdna-cdn.com/images/icons/icon5.gif [Broken]
I'm thinking you have not drawn the circuit correctly. You show the ammeter shorted out by a connecting wire. That wire also connects node 1 to node 2, making them one node. Please check and correct.
NascentOxygen
Mentor
9,215
1,056
At node 1, two of the terms you will probably have are V1/10 and (V1 + 100)/30 plus some more.
81
Thank you for any help that you can offer.
Did I answer all of the questions correctly and thoroughly? Can you please find any errors, and point them out to me so that I can fix them?
Calculate the input impedance looking directly into the base of the BJT
Calculate the output impedance including the 3.3k resistor
https://scontent-a-pao.xx.fbcdn.net/hphotos-prn2/t1.0-9/1900003_10151939940590919_952631427_n.jpg
Zin = (hFE + 1){ZLoad}
Zout = {(R10k)(R3.3k)/(R10k) + (R3.3k)}/(hFE+1)
1(a)
Zin = (hFE + 1){RL
Zin = (100 + 1){10 x 10^3(ohms)}
Zin = (101){10 x 10^3(ohms)}
Zin = {10.1 x 10^5(ohms)}
Zin = {1010k(ohms)}
1(b)
Zout = (R10k)(R3.3k)/(R10k) + (R3.3k)}/(hFE+1)
Zout = {(10 x 10^3(ohms))(3.3 x 10^3(ohms))/(10 x 10^3(ohms)) + (3.3 x 10^3(ohms)}/(100 + 1)
Zout = {2.481 x 10^3(ohms)}/(100 + 1)
Zout = 24.56(ohms)
Are there any errors?
Thank you.
623
137
Are you sure about Zout ?? Also check your numbers in Zin; ZL = ?
Jony130,
Okay, no, I am not sure about Zout. Seeing that my answers are not right. What assumptions can I make to improve my next attempt? What kind of questions does one ask to tackle a problem like this?
623
137
For this simple circuit with CCCS
try to find Zout = Vin/Iin for Vin = 1V and β = 100;
Answer
This is my answer to the question
Iin = IB + (hFE)(IB)
Iin = (hFE + 1)(Ib)
Ib = (Vin)/(Rb)
Iin = (hFE + 1){(Vin)/(Rb)}
Zout = (Vin)/(Iin)
Zout = (Vin)/[(hFE + 1){(Vin)/(Rb)}]
Zout = (Rb)/(hFE + 1)
Zout = (10k)/(100 + 1)
Zout = 99(ohms)
623
137
Very good, so Zout for your emitter follower circuit will be equal to Zout = ?
So Zout = {R10k/(100 + 1)}||{R3.3k}
623
137
Excellent work
81
Excellent work
Okay this is a revision of the whole problem. Can you please look at all eight questions and answers? Thanks Jony130.
Calculate VB neglecting loading of the bias network by the BJT
Calculate VE neglecting loading of the bias network by the BJT
Calculate IE neglecting loading of the bias network by the BJT
Calculate VB including loading of the bias network by the BJT
Calculate VE including loading of the bias network by the BJT
Calculate IE including loading of the bias network by the BJT
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-frc1/t1.0-9/1932404_10151940102460919_638617745_n.jpg
1(a): Calculate the input impedance looking directly into the base of the BJT
Zin = (hFE + 1){R10k
Zin = {1010k(ohms)}
1(b): Calculate the output impedance including the 3.3k resistor
Iin = [IB + (hFE)(IB)]{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
Iin = [(hFE + 1)(Ib)]{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
Ib = [(Vin)/(Rb)]{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
Iin = [(hFE + 1){(Vin)/(Rb)}]{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
Zout = {(Vin)/(Iin)}{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
Zout = (Vin)/[(hFE + 1){(Vin)/(Rb)}]{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
Zout = {(Rb)/(hFE + 1)}{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
Zout = {(10k)/(100 + 1)}{3.3k}/{(10k)/(100 + 1)} + {3.3k}
Zout = 96(ohms)
https://scontent-a-pao.xx.fbcdn.net/hphotos-prn1/t1.0-9/1964785_10151940672820919_881396491_n.jpg
2(a): Calculate VB including loading of the bias network by the BJT
rin = (hFE + 1){R}
rin = (hFE + 1){R7.5k
rin = (100 + 1){7.5 x 10^3(ohms)}
rin = (101){7.5 x 10^3(ohms)}
rin = {7.575 x 10^5(ohms)}
rin = {757.5k(ohms)}
IB = IE/(hFE + 1)
IB = {(VCC/R7.5k)/(hFE + 1)}
IB = {(15V/7.5k/(100 + 1)}
IB = 1.98 x 10^-5
IB = 19.8uA
VB = (rin)(IB)
VB = (757.5k)(19.8uA)
VB = 15V
2(b): Calculate VE including loading of the bias network by the BJT
VE = VB - VBE
VE = 15V - 0.6V
VE = 14.4V
2(C): Calculate IE including loading of the bias network by the BJT
IE = IE/R7.5k
IE = 14.4V/7.5k
IE = 1.92mA
2(D): Calculate VB neglecting loading of the bias network by the BJT
{R150k/(R150k + R130k)} x VCC = VB
150k/(150k + 130k) x 15V = VB
8.03V = VB
2(E): Calculate VE neglecting loading of the bias network by the BJT
VE = VB - VBE
VE = 8.03V - 0.6V
VE = 7.43V
2(F): Calculate IE neglecting loading of the bias network by the BJT
IE = IE/R7.5k
IE = 7.43V/7.5k
IE = 0.99mA
Thanks again for your help.
81
NascentOxygen,
This is a whole problem. Can you please look at all eight questions and answers and tell me if you see errors?
Zin = {1010k(ohms)}
Zout = 96(ohms)
rin = (hFE + 1){R}
IB = IE/(hFE + 1)
IB = 1.98 x 10^-5
IB = 19.8uA
VB = (rin)(IB)
VB = 15V
VE = VB - VBE
VE = 15V - 0.6V
VE = 14.4V
IE = IE/R7.5k
IE = 14.4V/7.5k
IE = 1.92mA
8.03V = VB
VE = VB - VBE
VE = 8.03V - 0.6V
VE = 7.43V
IE = IE/R7.5k
IE = 7.43V/7.5k
IE = 0.99mA
berkeman
Mentor
55,724
5,810
The ammeter is shorted out, as NO says. There is likely an error in your original post. Can you please check with the instructor?
berkeman
Mentor
55,724
5,810
Thread closed while we sort out multiple posts of the same question...
berkeman
Mentor
55,724
5,810
Thread re-opened after 2 threads merged.
Want to reply to this thread?
"Input/Output Impedance" You must log in or register to reply here.
Related Threads for: Input/Output Impedance
  • Posted
12K
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
