Output Equation: y(x)=Input+Initial Data Response
  • Thread starter asdf1
In summary, the equation y(x) = e^(-h)*(integral *(e^h)*rdx) + ce^(-h) can be viewed as the total output being equal to the response to the input (e^{-h}\int{e^{h}rdx}) and the response to the initial conditions (ce^{-h}). The term ce^{-h} represents the initial state, while r(x) is the input. The integral is a definite one, meaning it has specified limits and is a function of the input. The constant c is the initial value of the dependent variable y, and h is a constant determined by the independent variable x and the initial value x_0. This is demonstrated in the equation y
asdf1
734
if y(x)=e^(-h)*(integral *(e^h)*rdx) + ce^(-h)
then why can you look at that equation from this view:
total output = response to the input+response to the initial data
The term [tex]e^{-h}\int{e^{h}rdx}[/tex] is the response to the input and the term [tex]ce^{-h}[/tex] is the response to the initial conditions.
i know, but why?
In the expression, [tex]r(x)[/tex] is the input and [tex]c[/tex] is the initial state. So, the integral is a function of the input and the second term is a function of the initial state.
@@a
i thought c was a constant? why is that particular one the initial state?
r(x) is the input because usually x is the input, right?
[tex]x[/tex] is the independent variable. [tex]r(x)[/tex] is an arbitrary function of the independent variable and is the input to your system. [tex]c = y(x_0)[/tex] is the initial value of the dependent variable [tex]y[/tex]. [tex]h = a.(x - x_0)[/tex].
The integral is in reality a definite one. So:
[tex]y(x) = e^{-h}\int_{x_0}^{x}e^hr(x')dx' + c e^{-h}[/tex]
At [tex]x = x_0[/tex] [tex]e^{-h} = e^{-a.(x_0 - x_0)} = e^0 = 1[/tex] and the integral from [tex]x_0[/tex] to [tex]x_0[/tex] is zero. So,
[tex]y(x_0) = 0 + c.1 = c[/tex]
thank you very much! :)
by the way, do you mean that a "definite integral" is one that converges?
No, a definite integral is one that has specified limits, so its result is a number and not a function of the integration variable. As you can see, in my example, I used x' as integration variable and x as one of the limits. Relative to x', x is a constant.
thanks! :)
What is the purpose of the output equation?
The output equation, also known as the transfer function, is used to describe the relationship between the input and output of a system. It helps to analyze and predict the behavior of a system based on its initial data response.
What does y(x) represent in the output equation?
The symbol y(x) represents the output of the system at a given time x. It is the dependent variable in the equation and is affected by the input and initial data response.
How is the output equation derived?
The output equation is derived using mathematical models and equations that describe the behavior of the system. It takes into account the input, initial data response, and the system's properties to create a relationship between the input and output.
Can the output equation be used for any type of system?
Yes, the output equation can be used for any type of system, including physical, biological, and economic systems. It is a general way to describe the behavior of a system based on its input and initial conditions.
How is the output equation used in scientific research?
The output equation is used in various fields of science and engineering to study and analyze complex systems. It helps in understanding the behavior of the system and predicting its response to different inputs. It is also used for designing control systems and optimizing performance in various applications.
  • Linear and Abstract Algebra
